Do ferromagnetic materials do "spatial averaging"?
Ferromagnetic materials do not simply boost magnetic field strength linearly; instead, they exhibit "spatial averaging" effects that complicate this relationship. The expected linear amplification, represented by the relative permeability, fails to account for field continuity and boundary conditions at the material's edges. Measurements suggest that the induced field distribution is influenced by these boundary effects, which must be considered in any analysis. The finite length of the material also introduces additional boundary conditions that affect the field. Understanding these complexities is crucial for accurately modeling magnetic fields in ferromagnetic materials.
GaryLS
Hi Everyone -
I have a classical E&M physics problem that I've been tearing my hair out over. It relates to how ferromagnetic materials boost the field strength of a non-uniform magnetic field. My takeaway from college physics class was that (assuming there's no saturation in the material) the field inside a magnetic material is boosted linearly by a multiplicative constant. So if the field vector at any point in free space p is B(p), if that point in space is enclosed within a magnetic material, the field vector will be αB(p), where α is the relative permeability of the material. But based on some measurements I did, this doesn't appear that my takeaway was correct. It appears instead that there's some sort of "spatial averaging" going on inside the magnetic material, leaving me totally confused. Please see attached for a detailed description of my problem, with images, etc.
Can anyone explain what's going on here? Thanks in advance.
GaryLS said:
Hi Everyone -
In your simulation you use an arbitrary increase by a factor of 10 for the induced field within the ferrite core. Have you tried looking up the relative permeability of ferrite (it is more like 640)? Your approach of linear amplification of the induced field within the ferrite does not deal with continuity of the fields and derivatives of the fields at the boundaries of the ferrite material. Any solution of Maxwells equations has to include the behaviour at the boundaries between materials. This will modify the induced field distribution inside the inner perimeter of the ferrite material, within the ferrite material and external to the outer perimeter of the ferrite. The finite length of your ferrite will introduce similar boundary conditions at the axial endpoints as well. What does your experimental measurement suggest is happening? What conclusion can you therefore draw about the your simple linear amplification model of the field within the ferrite?
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
