Do Large Generators Really Use Permanent Magnets?
Large power plant generators typically do not use permanent magnets as their primary source of magnetic fields; instead, they often utilize electromagnets. Electromagnets allow for voltage regulation by varying the current in the field, although this can consume some of the generated electrical energy. Permanent magnet synchronous generators are noted for their higher efficiency compared to wound rotor types, largely due to advancements in high-energy permanent magnets like Nd2Fe14B. However, there are additional considerations and challenges associated with using permanent magnets in generators. Overall, the choice between permanent magnets and electromagnets involves a trade-off between efficiency and practicality in power generation.
cj
I frequently teach my students about how basic generators work (motional EMFs, Faraday's Law, magnetic flux, etc.).
Question: do the generators used at large power plants really use a permanent magnet as a source of the magnetic field?
I was thinking that maybe an electromagnet might be used as the source, but I'm not sure. Plus I'm thinking that providing the electricity to this kind of electromagnet might significantly offset the generated electical energy that is produced.
The field is an electromagnet. This is the way the voltage is regulated by varying the current in the field.
For generators and motors, how practical is using a permanent magnet with repsect to an electromagnet? In other words, how does the efficiency and power generation compare?
I found this http://www.windturbines.net/wiki/Synchronous_Generators". The author(s) of that page have claimed higher efficiency for permanent magnet synchronous generators than for the wound rotor type. But there are other issues with permanent magnet synchronous generators.
I have read the development of high energy permanent magnets (such as Nd2Fe14B magnets) have made permanent magnet synchronous generators more competitive with other types of generator.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
