Do the Fresnel equations of reflection apply to monochromatic light?
The Fresnel equations apply to monochromatic light for estimating reflectance and transmittance at the interface of two media. The index of refraction is wavelength-dependent, meaning it varies with the light's wavelength, which is crucial for accurate calculations. When monochromatic light passes through collimators, it can remain unpolarized depending on the setup and the nature of the light source. Understanding the relationship between wavelength and refractive index is essential for applying the Fresnel equations effectively. Overall, the discussion emphasizes the importance of considering wavelength when dealing with light interactions at media interfaces.
XLAYZ
Hello,
I have a monochromatic light source (wavelength ~ 420 nm), which will be incident on the interface of two different media. Could someone please explain if the Fresnel equations applies with monochromatic light when estimating the reflectance and transmitance?
Thank you in advance!
Fresnel equation:
Science news on Phys.org
Would it help if I pointed out that the index of refraction n = n(λ)?
Likes XLAYZ
Thank you for your hint, now I realized that I also need to take the wavelength into account.
BTW, when a constant monochromatic light (λ≈420 nm) passes through a ø 2.5 mm and 15 mm collimator to produce parallel light beams, is this light unpolarized? Thanks.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
