Voice Box
- 1
Here's a question no one at present seems to know the answer to.
In "Talk Boxes" from the 70s they used a light bulb as a limiter to prevent overload to the compression driver that then sent the sound into the plastic tube you have in your mouth.
I put a 33uf cap in series with the + lead to the compression driver and this seems even better giving a cleaner less distorted sound from the driver by reducing the lower frequencies.
But! when trying to measure the ohms to my valve amplifier the cap stops any ohms/load that can be read on my ohm meter.
Does this mean my amp is not getting a safe 8 ohms load on the valve output stage and could be damaged? or is this safe?
Cheers.
TB
Cheers.
TB
