Does a humam body movement generate a vacumm trail? and more
  • Context: Undergrad
  • Thread starter Thread starter Gabriel Ulisses
    Body Movement
The discussion centers on whether human body movement generates a vacuum trail and the implications of aerodynamic drag. A participant inquires about the necessary velocity for a body part with a volume of 60 cm³ to create a vacuum that exerts 78 megapascals of pressure over a 3-meter radius. Experts clarify that this pressure is unrealistic, as atmospheric pressure is only 0.1 megapascals, and emphasize that the phenomenon being described relates to aerodynamic drag, where a higher pressure area exists in front of a moving object and a lower pressure area behind it.
  • Understanding of aerodynamic drag principles
  • Basic knowledge of pressure measurement in megapascals
  • Familiarity with fluid dynamics concepts
  • Ability to perform calculations involving volume and pressure
  • Research the principles of aerodynamic drag and its effects on moving objects
  • Learn about pressure measurement and conversion between different units, including megapascals
  • Explore fluid dynamics and its applications in real-world scenarios
  • Investigate the physics of vacuum creation and its implications in various fields
Physics students, engineers, and anyone interested in the mechanics of motion and fluid dynamics will benefit from this discussion.
Gabriel Ulisses
I will start with an excuse, sorry english is not my main lengauge and i don't practice grammar that much, it is my first time in these forums so be kind, i hope i posted on the right forum thank you for the comprehension.
When you move your arm for example do you generate a trail of vacuum behind it? and does the air ocupating the vacuum space generate force?
I got as especific is i could get if you need anymore values for the calculations ask,i can give preety much anything.
How would you calculate:
What would be the nescessary velocity for a 60cm³ random body part of you (volume) to generate enough vacuum so the air ocupating it space would generate 78 megapascal of pressure on a circle of 3 meter radius?
Welcome to PF!
What I think you are referring to is aerodynamic drag. There is a higher pressure area in front of you and a lower pressure area behind. But 78 megapascal? Atmospheric pressure is only 0.1 megapascals, so no...
russ_watters said:
Welcome to PF!
I was expecting an absurd number, something actually inhumanly posible, and yes i think aerodynamic drag is watch I'm refeering to, it is the air ocupating the vacuum created by movement right?
  • · Replies 62 ·
13K
