Does adding heat affect work done by gas on its surroundings?
Adding heat to a gas during a cycle influences the net work done by the gas on its surroundings. In this case, the work done by the gas is calculated by considering the individual work values: Wbc is -3315.4J and Wca is -2108.98J. The total work done can be determined by summing these values, resulting in a net work of -5424.38J. The net heat added to the gas is 1200J, which indicates that the gas does work on its surroundings despite the heat input. Therefore, the relationship between heat added and work done is crucial in understanding the thermodynamic cycle.
nrc_8706
if heat is added to a gas for the entire cycle, does that affect the net work done by the gas on its surroundings for the entire cycle?
Wbc=0 Wab=-3315.4J Wca=nRTLn(Va/Vc)=-2108.98
The net heat added to the gas for the entire cycle is 1200J. Determine the net work done by the gas on its surroundings for the entire cycle.
Don't you just add the works?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
