Does alternator work as dynamometer?
In summary, Bob believes that the power produced from the small engine must be larger than the power produced by the engine. He chose an alternator that can produce 12V/75A in order to get the maximum value of power from the engine.
roti_mentega
does alternator work as dynamometer??
i'm doing small engine test rig to analyze it performance characteristic. then,i connect the pulley to alternator.thing that i need to considered is power that can produced from alternator must be larger that small engine.from engine specification, it can produces maximum power around 810Watt.so i choose alternator 12V/75A so i can get the maximum value of power from engine, by using P=IV
my question is it's true that power,P=IV that i calculated is true value of power from this small engine?
You will always have some losses in your systems. The use of alternators/generators as loads for engines is a well established practice.
thanks...so that why there are 2 type of power.brake power and indicated power.
but,it's right with my method to replace dynamo meter with alternator??
Are you asking whether electical power P=IV is the same as brake power? Brake power simply refers to a method of testing...so the answer, as far as I know, is yes.
this is what i mean.lol..! sorry,really bad in english.thanks Lsos for helping..
I'm not sure what you mean by "brake power", but the shaft power of an electric motor and the input power (P = IV) are not the same thing.
The shaft power is reduced by the efficiency (and power factor if it's an AC motor) of the electric machine.
CS
what I'm understand is brake power mean that power produced from engine and some losses occur during power transmitted to it shaft.
btw,how could i know the power factor for this AC motor?
Power factor should be on the nameplate of the motor.
CS
The power produced from the reciprocating engine at the crankshaft/flywheel is essentially the same as the shaft power of an electric motor (some energy source - fuel or electricity - being transformed into mechanical energy). Thus the input power (apparent power for electric motor and equivalent energy of the fuel) will not equal the shaft/brake power. The irreversibilities in the conversion process reduce it as previously noted.
CS
They're the same thing, as in the same physical concept and the same units: they're both measures of energy/ time. But, as I was hoping someone would clarify (as stewartcs did) it's important to realize that this "energy/ time" is measured at different places.
P=IV is taken at the terminals. You hope most of it gets from the terminals to the shaft, (or from the shaft to the terminals, as in the alternator's case) but whether it's actually 90% or 0% is a different story. Brake power is, as the name implies, the power that a brake attached to the engine shaft measures. It's important to take all this into consideration...
Here are definitions of brake and indicated HP from Wikipedia:
Indicated horsepower (ihp)
Indicated horsepower (ihp) is the theoretical power of a reciprocating engine if it is completely frictionless in converting the expanding gas energy (piston pressure × displacement) in the cylinders. It is calculated from the pressures developed in the cylinders, measured by a device called an engine indicator—hence indicated horsepower. As the piston advances throughout its stroke, the pressure against the piston generally decreases, and the indicator device usually generates a graph of pressure vs stroke within the working cylinder. From this graph the amount of work performed during the piston stroke may be calculated. It was the figure normally used for steam engines in the 19th century but is misleading because the mechanical efficiency of an engine means that the actual power output may only be 70% to 90% of the indicated horsepower.
[edit] Brake horsepower (bhp)
Brake horsepower is the measure of an engine's horsepower without the loss in power caused by the gearbox, alternator, differential, water pump, and other auxiliary components such as power steering pump, muffled exhaust system, etc. Brake refers to a device which was used to load an engine and hold it at a desired RPM. During testing, the output torque and rotational speed were measured to determine the brake horsepower. Horsepower was originally measured and calculated by use of the indicator (a James Watt invention of the late 18th century), and later by means of a De Prony brake connected to the engine's output shaft. More recently, an engine dynamometer is used instead of a De Prony brake. The output delivered to the driving wheels is less than that obtainable at the engine's crankshaft.
Bob S
hurmm ... let say i run my engine with speed around 3000rpm.then i put a bulb as load for 100Watt.then i increase the load to 200Watt.what happen to power while i maintain the speed(still 3000rpm,where it will decrease when load is increase).. the power will increase will increase or decrease ??
what if the engine direct with alternator using shaft?is that ok?
Should be fine, just make sure it's all mounted correctly and that you aren't going to overspeed the alternator.
what kind of load suitable we use if using alternator as dyno?
how its operate?
i used bulb as load...but this experiment not got what i need.it not easy to maintain the rpm of small engine.lol~
how much your engine horsepower? and how many watts you used?
i using grass cutter engine...very low hp.and i use variable load(bulbs)
how you running the test? procedure of testing...
can u expain it...
you using AC or DC current?
Bulbs and resistive heating elements should be fine. Speed control can be tricky, does the engine have a governor?
the engine have a govenor...
but how the procedure of the testing?
I have a list of around 80 different test procedures for an engine on a dynamometer. Just asking for a test procedure, without any indication as to what you want to establish isn't going to get you very far!
Either the engine wasn't running under the same conditions in each test, your calibration (dyno or alternator) is wrong, or you've slipped up. There's no inherent reason you should be seeing such different results.
Is the plot the engine's power curve? In the alternator case, is torque measured or calculated from power? Is it a DC alternator?
yes...it is the plot engine power curve...
the torque for alternator is calculted from power. and it is ac alernator...
Can you please describe how you took the test data. How did you apply load to the alternator to ensure that you were running on the power curve? Did you just put the throttle wide open and lug the engine? If the engine was truly under the same load for both tests (engine operating under the same conditions, with same throttle position and fuelling etc) then there's an error with the way you've measured power in one instance.
On your power curve for both tests, plot:
- fuel flow rate
- air mass flow rate
- exhaust temperature
Then we'll see whether the power was different in both instances or whether it's just a measurement problem.
1. How does an alternator work as a dynamometer?
An alternator works as a dynamometer by converting mechanical energy into electrical energy. When a force is applied to the alternator's rotor, it turns, causing the stator to produce an electromagnetic field. This field then induces a current in the stator windings, which can be measured to determine the amount of force applied to the rotor.
2. Can any alternator be used as a dynamometer?
No, not all alternators are designed to function as dynamometers. Alternators used as dynamometers need to have a specific design to accurately measure force and torque. They also need to have precise calibration and instrumentation to accurately measure and convert electrical output into force or torque values.
3. What are the advantages of using an alternator as a dynamometer?
One advantage of using an alternator as a dynamometer is its ability to measure both force and torque, making it a versatile tool for testing different types of machinery. Additionally, alternators are relatively easy to install and maintain, making them a cost-effective option for measuring force and torque.
4. How accurate are alternators as dynamometers?
The accuracy of an alternator as a dynamometer depends on its design, calibration, and instrumentation. With proper calibration and instrumentation, alternators can provide accurate measurements within a close range of the actual force or torque applied.
5. Can an alternator be used as a dynamometer for high-speed applications?
Yes, alternators can be used as dynamometers for high-speed applications. However, the alternator's design and instrumentation need to be specifically suited for high speeds to ensure accurate measurements. Additionally, regular maintenance and calibration are crucial for accurate readings at high speeds.
  • Mechanical Engineering
  • Electrical Engineering
