schaefera said:
As I understand, we should treat length contraction as if all space in the moving frame is contracted-- that is, the distance between two objects as well as the objects themselves are cotracted by a factor of gamma.
If this is correct, wouldn't the string in Bell's paradox NOT break- because a stationary observer does see the string contract, but only just as much as the distance between the ships shrinks?
Here's a simpler version of Bell's spaceship paradox. The simplification loses Bell's more important and interesting point about how accelerations at diffent locations transform, but it does explain why the string breaks.
Suppose the spaceships don't start at rest; instead they're zooming by the ground-based observer at a constant velocity and separated by a distance D in the ground-based frame. Furthermore, the two spaceships aren't yet connected by the string. Instead, two daredevil acrobats are standing on the ground, separated by the same distance D and holding the ends of a string of that length.
As seen by the acrobats and the ground frame observer, the spaceships are separated by a distance D and so are the acrobats. So each acrobat will see a spaceship pass overhead at the same time in their ground frame. At this exact moment, both acrobats leap into the air and grab hold of the spaceship passing overhead.
Being strong and capable daredevil acrobats, they manage to grab their spaceship with one hand while holding onto their end of the string with the other. They each experience an enormous jerk as their spaceship drags them off, but once they've recovered from that shock, we have our two acrobats and the string now moving at the speed of the two spaceships.
The string was of length D when it was rest relative to the ground-based observer, but now it's moving relative to that observer, so is length-contracted. The distance between the spaceships is still D relative to that observer, so the string breaks.
For an observer on either spaceship (both moving at the same constant speed, so in the same frame) relativity of simultaneity means that the two acrobats grab the spaceships at different times. The lead acrobat goes first, while the trailing acrobat is still standing on the ground. The string stretches and breaks as one end is being pulled by the lead ship while the other end is still anchored.
