Does Bromobenzene Indicate Bromine on Every Carbon in the Benzene Ring?
Bromobenzene refers specifically to a compound where a single bromine atom is bonded to one carbon in the benzene ring, not to every carbon. The designation of 1-bromobenzene indicates that the bromine is attached to one specific carbon, but the exact position is not critical due to the symmetrical nature of the benzene ring. When naming compounds like 1-ethylbenzene, the ethyl group is attached to one of the carbons in the ring, and the position of the bromine can vary without altering the molecule's identity. The ability to rotate the benzene ring means that the orientation of the bromine does not affect the overall structure. Therefore, bromobenzene is understood to mean 1-bromobenzene, with the specific carbon position being less significant.
PhysicBeginner
Does bromobenzene mean that a bromine is bonded to every carbon in the benzene ring?
When it saids 1-ethylbenzene where do i put the ethyl since benzene is in a ring?
Thx in advance
no just one one carbon of the benzene, 1-bromobenzene.
so is it infered that whenever i see bromobenzene it means 1-bromobenzene? and where would i put the bromine if its 1 only?
It doesn't matter which carbon gets the bromine, since the resulting molecule can be rotated arbitrarily. In other words, sticking a bromine on the bottom or a bromine on the top results in the same molecule. If you stuck it on the top, you could rotate the resulting molecule to make it appear on the bottom. The molecule isn't changed by simply being rotated.
- Warren
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
