Does every group whose order is a power of .
  • Thread starter Thread starter Jamin2112
    Group Power
The discussion revolves around the properties of groups whose order is a power of a prime \( p \). The original poster questions whether such groups necessarily contain an element of order \( p \), relying on Lagrange's Theorem and related concepts.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the implications of Lagrange's Theorem and consider the application of Cauchy's theorem. There are discussions about the structure of cyclic subgroups generated by elements of the group and the distinct elements within those subgroups.
Participants are actively engaging with the problem, questioning the properties of elements within the subgroup generated by \( g \). Some guidance has been offered regarding the nature of cyclic groups and the order of elements, but no consensus has been reached on the existence of an element of order \( p \).
There is some confusion regarding the notation and definitions, particularly concerning the identity element and the distinct powers of elements in the subgroup. Participants are also clarifying the conditions under which elements have specific orders.
Jamin2112
Does every group whose order is a power of ...
Does every group whose order is a power of a prime p contain an element of order p?
I'm trying to get away with only using Lagrange's Theorem and a corollary thereof.
Seems like I'm almost there. How do I seal the deal? Thanks in advance, brahs.
You could use Cauchy's theorem, but that's overkill for this problem. Sure, finish your approach. If m is the order of some element g, then the group generated by g is a subgroup of order p^k for some k. And the subgroup generated by g is CYCLIC. Use that!
The subgroup generated by g is <g>={..., -g2, -g, 1, g, g2, ...}, which is the smallest subgroup of G that contains g, and has order pk for some integer k≥0. Since pk is not infinite, the elements of <g> are not distinct, so ... am I getting somewhere?
I think we are using multiplicative notation here. The distinct elements of the subgroup generated by g are {e,g,g^2,...g^(p^k-1)} since g^(p^k)=e. Now get somewhere with that. Isn't there an element of order p in there?
*pssst* ... What's e?
e = indentity element of group G
Got it.
Can you explain once more where we got {1, g, g2, ..., gpk-1}.
My book says "Let <x> be the cyclic group of a group G generated by an element x, and let S denote the set of integers k such that xk=1.
Suppose that S is not the trivial subgroup. Then S = Zn for some positive integer n. The powers 1,x,x2,...,xn-1 are the distinct elements of the subgroup <x>, and the order of <x> is n."
But I'm a little confused by it.
The subgroup generated by g is just the collection of all distinct powers of g. It's a subgroup since (g^a)(g^b)=g^(a+b). If the order of g is 5 then that's {1,g,g^2,g^3,g^4}. No use listing g^5 since that's 1 or g^6 since g^6=g^5*g=g. Now your case is order g equal to p^k.This is simple enough that I wouldn't spend a lot of time confusing yourself about it.
This right?
Jamin2112 said:
This right?
Why do you think g^p has order p? And that's not generally correct. Proofs usually involve giving reasons. What's (g^p)^p? Why would that be 1?
Never mind. So I'm looking for an element in {1, g, g2, ..., gpk-1} that has order p, i.e., the cyclic subgroup generated by that element this element has p elements. So if I let x be that element, the cyclic subgroup generated by x is {1, x, x2, ..., xp-1}. Am I right?
Yes. You want x^p=1. Which nonidentity element of {1, g, g2, ..., gpk-1} might have that property? Think about exponents ok? (g^a)^p=g^(ap) right? THINK!
