Does every object rotate around its center of gravity?
The discussion revolves around the question of whether every object rotates around its center of gravity (CG), with a focus on the differences in rotational behavior between rockets, planes, and boats. Participants explore theoretical and practical implications of rotation in various contexts, including fluid dynamics and the mechanics of motion.
  • Some participants argue that rockets and planes rotate about their center of gravity, while questioning why boats do not follow the same principle.
  • Others point out that boats have additional structures like keels and centerboards that influence their pivot points and rotational dynamics.
  • A participant mentions that the AC75 racing boat's design allows it to rotate around a point outside its hull, emphasizing the importance of considering all forces, not just gravity.
  • There is a discussion about how planes can be viewed as pitching about a horizontal axis through the wings, while sailboats can be seen as yawing about a vertical axis through the centerboard.
  • Some participants express confusion regarding the relationship between center of gravity and center of pressure in rockets, particularly in terms of stability and rotation.
  • It is noted that the choice of reference point for describing rotation is flexible, and different points can yield valid descriptions of motion.
  • Participants highlight that a rigid object in isolation will typically rotate about its center of mass, but external forces can alter this behavior.
Participants do not reach a consensus on whether all objects rotate around their center of gravity, with multiple competing views and ongoing confusion regarding the implications of fluid dynamics and rotational mechanics.
Participants mention various assumptions and conditions, such as the effects of external forces on rotation and the influence of fluid density on the behavior of boats compared to aircraft.
  • #91
A.T. said:
Look at:
https://en.wikipedia.org/wiki/Terminal_velocity
Just replace the constant gravity with your constant thrust.
But space don't have fluid,I just say fluid as example for reference point ..Fixed point in space
  • #92
There is no absolute rest, if that's what you mean.
  • #93
What frame use ussualy when people talk about rocket speed in space?
  • #94
I am in rocket when engine is turn off.I get out of rocket and rocket turn ON engine and going away from me..
What is rocket speed in relation to me?
  • #96
John Mcrain said:
Engines are same,have equal thrust...
Stick is is deep space,engine 1 is act at CM, engine 2 is turn OFF,stick travel with constant speed v.
In time t1 I turn OFF engine 1 and turn ON engine 2.
Will stick start rotating counterclock wise or it will keep going in straight line without rotation?
The stick will not rotate in this case. From the problem statement, we are given that the engine acts at the center of mass. That means that the engine is just a bit right of center on that huge massy blob. Just enough right so that things remain balanced.
Please do not present drawings that disagree with the accompanying text.
  • #97
We pick one that is convenient.
For a rocket on a sub-orbital trajectory aimed at a target, we might use the rotating frame in which the surface of the Earth is stationary.
For a rocket in orbit around the Earth, we might use the inertial frame in which the center of the Earth is stationary.
For a rocket making a trip to the moon, we might switch frames in the middle of the trip. [It would be foolhardy for Neil Armstrong to be using the earth-centered inertial frame when descending the last 30 meters to land on the moon].
For a rocket making a slingshot maneuver, we can shift frames and observe how a trajectory which conserves spacecraft mechanical (kinetic + potential) energy in one frame increases it in another. This might confuse us until we realize that energy is conserved but is not invariant.
  • #98
Again, you need to specify the point of rotation you are asking about. “Will stick start rotating counterclock wise about the CG or it will keep going in straight line without rotation?” If you find that too cumbersome then the word “spin” refers to “rotation about the CG” in classical physics.
  • #99
I am inclined to let this one pass.
The rate of change of orientation of a rigid object is an invariant. It does not depend on a choice of reference axis.
If we were asked about the rate of change of angular momentum, then the reference axis would [usually] matter.
  • #100
I am not. His questions are exceptionally sloppy. This is one topic that he has been specifically instructed about from the very first page. That this far into it he still is being sloppy indicates an unwillingness to learn or improve.
  • #101
Exactly. For rotation as change of orientation of the rigid body the reference point doesn't matter. It matters for translation, torques and angular momentum.
  • #102
A.T. said it will..
  • #103
John Mcrain said:
A.T. said it will..
I think @jbriggs444 was thrown by the errors in the description and diagram. If only engine #2 is firing, which is not at/through the COM, it rotates.
  • #104
You know what I am talking...
  • #105
Actually, not usually. Care and clarity helps both the poster and the responder.
  • #106
I made mistake ,because I forgeot stick will accelerate in space becasue there is no any drag to counter force ,so question don't make sense at all..
  • #107
John Mcrain said:
A.T. said it will..
I had incorrectly assumed you were firing the engine under the big mass, not the engine at the tip of the rod.
  • #108
A.T. said:
If only rocket 2 is OFF, the stick will not travel with constant speed.
If engine 2 in ON,stick will accelerate again,because in space drag don't exist.
Stick will accelerate in any combination of engines,both ,only left or only right..
Isnt it?
  • #109
You also appeared to locate engine 1 at the COM of the large object, not at the COM of the system.
But anyway, since we don't know where you are going with these questions, it is tough for us to error-check your overall logic. If you only want to know about rotation, it shouldn't matter that the system is also accelerating linearly -- we could simply ignore that. Maybe there's something else on your mind...
Isnt it?
Yes. Didn't you do this experiment with a pencil like I suggested?
  • #110
No this is CoM from all system..Forget about it because it doesn't make sense at all,because system is accelerating,so mass show resistance to change speed again
  • #111
K
  • #112
Yes I know for this test.
I try to prove something else,but now I see that this what I mean is impossible.
Now I realize that for constant speed you must allways have two opposite forces equal in magnitude,so net force again is zero.In space this second opposite force- drag force don't exsit.
  • #113
This is true for constant velocity. For constant speed (magnitude of velocity) you can have a net force, that is perpendicular to velocity.
  • #114
Yes, but the term for the rate of change of the orientation of a classical object is "spin", rather than "rotation" which is more general.
  • #115
What is rocket speed in relation to me and how would I call this place in space where I am now if I want that place would be my origin of my reference frame?
  • #116
  • #117
Suppose you are in an inertial frame of reference at rest or not with the ship.
Case 1 Both engines off, the ship continues at rest or in uniform rectilinear motion.
Case 2 You turn on motor 1, you apply force 1, on the MC, it accelerates in translation at a rate of ##a_1 = \dfrac{F_1}{M}##, but it does not rotate, the angular acceleration is zero ## \alpha = 0 ## since the lever stroke regarding the MC is null.
Case 3 Turn off engine 1 and turn on 2 The MC accelerates in translation at the rate of ## a_2 = \dfrac{F_2}{M} ## in the same direction as the force is applied and in turn rotates with angular acceleration ## \alpha = \dfrac MI = \dfrac{F_2L}{KML^2} ## Where K is a value that depends on the design of the ship, which is irrelevant, the important thing is that ## \alpha \neq 0 ## The speed of the MC in both cases results from ## v =\displaystyle \int_0^T \dfrac {F (t)}{M (t)} dt ## only for brief instants ## v \cong at ##, because both a The force and the mass can be variable in time, because we know that we can vary the thrust by increasing fuel consumption, the mass also varies because we consume the fuel, so these formulas are strictly not true, so it is more I must study what they propose you about the Tsiolkovski rocket.
Considering the same limits, in a few moments you can say that the rotational speed or angular velocity will be ## \omega = \displaystyle \int_0 ^ T \dfrac {F (t) L}{KM (t) L^2} dt ## then we can say that ## \omega \cong \alpha t ##
If you introduce resistive forces, these can be summarized as a single force with direction and direction applied at a point of thrust by modifying the modulus of the translational acceleration, It will also influence the acceleration of the turn, if the axis of the resultant force does not pass just through the MC, since it will have a non-zero lever arm, and will create torque.
  • #118
They all try to. Without any other forces, they will, but even a spacecraft will deviate when thrusters are fired,
  • #119
It's because the mathematics are such that when dealing with a *rigid* body, the body force - i.e., gravity or centrifugal acceleration (if the radius of the spin is much larger than the volumetric extent of the body) - cancels out at the barycenter, and a net applied load (i.e. force & force couple moment) can be abstracted out to be a force & moment applied to the barycenter, with the inertia-acceleration equations being decouple.
  • #120
Turn off the boat's engine and lift it out of the water. Now fling it into the air. It will then rotate around its center of mass.
  • · Replies 141 ·
  • · Replies 29 ·
  • · Replies 49 ·
  • · Replies 38 ·
  • · Replies 51 ·
  • · Replies 24 ·
