Does the Efficiency of a Steam Boiler Generator Depend on Load?
The efficiency of a steam boiler generator is indeed dependent on the load. As the load changes, the proportion of inefficiencies, such as heat loss and mechanical friction, also varies, affecting overall efficiency. For instance, constant losses like heat loss do not change with load, leading to lower efficiency at reduced outputs. Additionally, mechanical friction losses become a larger fraction of the input work when the load is lower. Therefore, both participants in the discussion are correct in recognizing that efficiency varies with load.
gentatsuki
Hi, my friend and I were having discussion on the efficiency of a steam boiler in our thermodynamics lab (he has a model of a steam boiler in the thermodynamics lab). He told me that the efficiency of the steam boiler generator is dependent on the load. I thought it was absurd, saying that the efficiency of the generator has to be the same regardless of how much you load it. Apparently they vary the resistance value using a potentiometer for their experiment.
Which of us is right?
Welcome to PF.
The efficiency of both a steam engine and a generator will vary with load. Often the sources of inefficiency, such as heat loss through the boiler are not functions of load, so they are constant while the load changes. For example, a steam engine that puts out 100W while losing 100W through convection due to imperfect insulation and another 100W through heat rejection (total 100/300=33% efficient) will still lose 100W when it is putting out 50W (50/250=20% efficiency).
A generator will have mechanical friction losses that do not vary with load (for a constant speed generator anyway), so they make up a larger fraction of the work input when the load is lower.
Thanks, that helped me a lot :D
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
