Understanding Domains and Ranges for Inverse Functions - A Noob's Guide
  • Thread starter Thread starter elemis
    domains Noob
The discussion centers on the relationship between the domains and ranges of a function and its inverse, particularly when they share the same equation. It is established that if f(x) and its inverse f-1(x) have the same equation, their domains and ranges do not necessarily have to match. An example provided is f(x) = -x, where restricting the domain affects the range of the inverse. The key takeaway is that the domain of f becomes the range of f-1 and vice versa, but this does not imply equality in specific cases. Ultimately, the domains and ranges can differ even when the functions are equivalent.
elemis
Supposing I have a function f(x).
Let us suppose that f-1(x) has the same equation as f(x).
Will the domain and range as defined for f(x) be the same as for the inverse ?
Mathematics news on Phys.org
In general, if f-1 is the inverse of f, then the domain of f is the range of f-1, and vice-versa. So your question becomes, "if f has the same equation as its inverse, then does its range have to be the same as its domain?" The answer to that is "no". Consider f(x)=-x, and try restricting the domain of f to some subset of the real numbers.
No, you misunderstood the question I posed.
Lets us say that the range for f(x) is f(x) > 3 and its domain is x>0
Now let's say f-1(x) has the same equation as f(x).
Will f-1(x) have the same range and domain as f(x) ? That is, will the domain be x>0 and the range f-1(x)>3 ?
Tinyboss understood you perfectly, and gave a counterexample.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
