Don't the magnetic poles affect radioactive decay?
Radioactive decay rates are generally constant, supported by extensive evidence, although some elements may exhibit slight variability that is accounted for. Carbon-14 dating is not 100% accurate due to fluctuations in cosmic ray production, but these variations average out over time, making the long-term carbon-14 levels relatively stable. Time itself is relative, with observers experiencing it consistently, despite theoretical fluctuations. The Caesium standard for atomic clocks, defined by a specific frequency, is minimally influenced by the Earth's magnetic field, which shifts slowly and has negligible effects on atomic decay. High-precision atomic clocks mitigate potential errors from magnetic influences through careful design and shielding.
Tzimtzum
Also, How do we know the radioactive decay is constant? I know that carbon dating cannot be 100% accurate because the rate of production fluctuates based on cosmic rays hitting our upper atmosphere. Why isn't this true with Earth metal isotopes?
Is time truly constant? It seems like a lot of variables could make it fluctuate.
Assuming your post is focused entirely on carbon-14 age dating, you've asked several questions; for starters, all radioactive decay processes other than electron capture have fixed rates.
Does that clear up that first question?
Paraphrasing, you mean to ask, "Is a measured carbon-14 age invariant?"
No.
You have noted that the production rate varies, depending on cosmic rays, shielding by the magnetic poles, and other things.
Wiki isn't too bad a start for some of the mistakes that have been made in applying the technique https://en.wikipedia.org/wiki/Radiocarbon_dating
We have lots and lots and lots of evidence suggesting that most types of decay are constant and very little/no evidence suggesting otherwise. There are a few elements that can have slight variability in their decay, but these are known and accounted for. More info here: http://math.ucr.edu/home/baez/physics/ParticleAndNuclear/decay_rates.html
It's not 100% accurate because 100% accuracy is impossible. The fact that carbon-14 is produced by cosmic rays is what allows us to do carbon dating in the first place. Fluctuations in the rate of cosmic rays striking the atmosphere probably averages itself out in the long term, which is what matters. The amount of carbon-14 in the atmosphere changes very little on a shot term basis.
See my link above.
Time is relative and can be different for different observers, though each observer sees themselves as passing through time at a rate of one second per second. However there are actually very, very few variables and time doesn't fluctuate the way you're most likely imagining it can. Look into Special and General Relativity for more info.
Oh wow, I was really was tired when I wrote this. I meant to say atomic decay not radioactive decay. Though the fluctuation of radioactive decay is what original made me wonder about this.
https://en.wikipedia.org/wiki/Caesium_standard
"By definition, radiation produced by the transition between the two hyperfine ground states of caesium (in the absence of external influences such as the Earth's magnetic field) has a frequency of exactly 9,192,631,770 Hz."
Does this mean the Caesium standard is influenced by the magnetic field? The poles are shifting more and more each year. I think it's at 40 miles per year now. Would this affect the atomic decay?
Even using the term "atomic decay" is reminiscent of radioactivity.
The energy levels of all atoms are affected by external magnetic fields. Some levels will shift to higher energies in the presence of the field, other will shift down in energy. Except for very strong magnetic fields (and the Earth's magnetic field is very weak), this shift in energy is minuscule. Nevertheless, when building a very-high-precision atomic clock, tiny shifts can introduce significant errors.
One way to maintain a high precision is built in the standard itself: only one substate of each of these two hyperfine ground states of caesium is considered, ##M_F = 0##, because these states are not affected by a magnetic field, to first order. But higher-order terms are still relevant to achieve high precision. So additional measures are taken, such as magnetic shielding or using external magnetic fields to counteract the Earth's magnetic field.
The shift in the Earth's magnetic field is not very important. What is important is the local value of the field where the clock is.
Likes Tzimtzum
M 7.6 - Drake Passage 2025-10-10 20:29:20 (UTC) 60.196°S 61.799°W 8.8 km depth https://earthquake.usgs.gov/earthquakes/eventpage/us6000rgf4/executive A relatively shallow earthquake. Aftershocks have occurred. M 7.4 - 20 km E of Santiago, Philippines 2025-10-10 01:43:59 (UTC) 7.265°N 126.755°E 58.1 km depth https://earthquake.usgs.gov/earthquakes/eventpage/us6000rfwz/executive M 6.7 - 23 km ESE of Santiago, Philippines 2025-10-10 11:12:07 (UTC) 7.172°N 126.755°E 61.2 km depth...
Thread 'The Secrets of Prof. Verschure's Rosetta Stones'
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....) Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam. What changed this...
