Dopple Effect (Frequency vs Time)
  • Thread starter Thread starter SpringPhysics
    Time
The discussion focuses on calculating the altitude of a jet airplane using the Doppler Effect, specifically analyzing the observed frequency versus time graph. Participants explore how to determine the observed frequency as a function of the horizontal distance from the observer to the jet's vertical position. The conversation emphasizes resolving the jet's velocity into components, with the vertical component affecting frequency and the horizontal component not impacting it. The derived formulas for frequency changes when the jet is approaching or receding are also discussed. Overall, the thread provides insights into applying the Doppler Effect to solve the altitude problem.
SpringPhysics
Doppler Effect (Frequency vs Time)
A jet airplane is flying above an observer parallel to the ground with speed vj. Given the observed frequency vs time graph, would you be able to calculate the altitude of the jet airplane? Explain, also, how to determine observed frequency as a function of x, where x is the initial horizontal distance of the jet airplane to the vertical directly above an observer.
v = \lambdaf
x = vt
I am really clueless on how to start this - I've been staring at this question for over an hour.
Is it true that if I find two values of time so that the inverse of the difference is a value of frequency on the graph, then that frequency is the frequency of the jet airplane? (The only problem is that if the jet airplane is initially moving away, this value will not be on the graph.)
Can someone give me a lead please?
Resolve vj into two components. vj*sinθ towards the observer.And another component vj*cosθ perpendicular to the line joining jet and the observer. θ is the angle between vertical and line joining the jet and the observer.
vj*sinθ changes the frequency where as vj*cosθ does not affect the frequency.
So f' = [v/(v-vj*sinθ)]*f for approaching jet and f' = [v/(v + vj*sinθ)]*f for receding jet.
Sinθ = x/sqrt(x^2 + h^2) and x = vj*t.
Ohh I get it now. Thanks a lot!
