Doppler effect Indianapolis 500 problem
The discussion revolves around calculating the speed of a car at the Indianapolis 500 using the Doppler effect, where the sound frequency drops by a factor of 1.5 as the car passes. The initial equation presented for this calculation is unclear, and the user struggles to identify the correct frequency values. It's clarified that the factor of 1.5 relates to the ratio of frequencies when the car approaches and recedes. A suggestion is made to set up separate equations for the frequencies when the car is moving toward and away from the observer, allowing the source frequency to cancel out. This approach will ultimately lead to a formula for determining the car's speed based on the speed of sound.
RedHotLlama18
At the Indianapolis 500, you can measure the speed of cars just by listening to the difference in pitch of the engine noise between approaching and receding cars. Suppose the sound of a certain car drops by a factor of 1.50 as it goes by on the straightaway. How fast is it going? (Take the speed of sound to be 343 m/s.)
answer given in km/h
v= (1- (f/(f prime/1.5))v
where the second v is the speed of sound.
Sorry it isn't a cleaner equation, I couldn't figure out how to get my mathtype equation from microsoft word here.
The equation above is my attempt at a solution, since the sound of the cars frequency drops by 1.5 that's what I divided my f prime by. I just don't know how to figure out the f values. Maybe I am using the wrong equation, I just can't figure out any other way to solve for the speed of the car. Any hints would be greatly appreciated and I thank you for your time.
1.5 IS f/f'. You don't need to know the values of f.
And be careful. When the car is coming toward you it's doppler shifted up in pitch and when it leaves you it is shifted down. As I read the question there is a factor of 1.5 between the ratios of those two pitches.
Welcome to the forums!
I don't quite see how you got your equation but I have a feeling that you used incorrectly the factor of 1.5.
Set up an equation for the frequency of the sound when the car is going toward you. Call this frequency f^'. It will contain the frequency emitted by the source that I will call f_{source} to be clear. Now find an expression for the frequency when the car is moving away from you. Let's call this f double prime = f^{''}.
What they are telling you is that \frac{f^'}{f^{''}} = 1.5. So take the ratio of your two equations and you will see that f_{source} will drop out, leaving you with an equation for the speed of the source (the car) in terms of the speed of sound.
