Simplifying Double Angle Formula: Cos^2 8x - Sin^2x
  • Thread starter Thread starter Veronica_Oles
    Angle Formula
The discussion centers on simplifying the expression cos^2(8x) - sin^2(x). Participants explore various approaches, including using the double angle formula and rewriting sin^2(x) in terms of cos(x). It is noted that expressing the equation in terms of only cos(x) and sin(x) leads to a more complex result, questioning the definition of "simplify." Ultimately, a reduction identity is suggested, leading to the expression cos(9x)cos(7x) as a desired simplification. The conversation highlights the challenges and nuances of mathematical simplification techniques.
Veronica_Oles
Simplify cos^2 8x - sin^2x
I thought it would be in the format of cos2x
But I can't seem to figure it out I tried cos (4 * 2x)
And I tried to change the sin^2x into 1-cos^2x and I could get any farther.
Not sure how else to simplify.
Try writing it as cos(2*4x), or let u = 4x and then do it with cos(2u).
EDIT:
Sorry, I rushed through reading your problem. What tools do you have other than the double angle formula? You might be able to write this as a difference of squares first, then apply some identities.
Do you know what the result should look like? How do you know when it is simple enough?
Thanks.
What, really, is meant by "simplify"?
The original result is about as simple as it gets. If you try to express everything in terms of ##\cos(x)## and ##\sin(x)## alone, your expression ##\cos^2 (8x) - \sin^2 x## becomes
$$ 1-\sin^2 x -64 \cos^2 x + 1344 \cos^4 x - 10752 \cos^6 x + 42240 \cos^8 x\\ - 90112 \cos^{10} x
+106496 \cos^{12} x -65536 \cos^{14} x +16384 \cos^{16} x $$
Would you say that expression is simpler than the original one?
Likes RUber
EDIT:
Thanks.
There is no solution unfortunately it was just a problem given:(
Yeah first one is definately simpler.
Veronica_Oles said:
Yeah first one is definitely simpler.
I have done this problem before, In my book they wanted it to be
##\cos(9x)\cos(7x)##.
use reduction identities
$$\cos^2(8x)=\frac{1+\cos(16x)}{2}\\
\sin^2(x)=\frac{1-\cos(2x)}{2}$$
