Is Double Glazing Worth the Cost for Heat Transfer?
  • Thread starter Thread starter katehovey
katehovey
I have a question about heat tranfer across single and double glazing but have come stuck.
The question is:
A window, 3m wide by 1.5m high, originally contained a single pane of glass 6mm thick. It is proposed to install double glazing consisting of two sheets of glass (each 6mm thick) separated by a stagnant air gap 20mm thick a ta cost of £600. If heating costs 4.5p per kWh, estimate the time taken to recover the cost of the double glazing when the temperature difference between inside and outside surfaces of the glass window is 20'C.
Thermal conductivity of glass = 0.8W/mK
Thermal conductivty of air = 0.025W/mK
I worked out the heat flow over the double glazing to be:
Q = 110.43W
And over the dingle glazing to be:
Q = 12000W
Both seem far too high, so I don't think they are correct. Also, I don't know where to go from here ifthey are correct.
Thanks
Are those units Watts/milli-Kelvin ? If so, did you scale your temperature properly ?
No sorry Watts per meter per Kelvin. But it's ok - I've finished the question now.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
12K
