Double integral: Cartesian to Polar coordinates
The discussion revolves around evaluating a double integral in Cartesian coordinates and converting it to polar coordinates. The integral involves the expression √(x² + y²) over a specified region defined by inequalities for x and y.
  • Participants explore the conversion from Cartesian to polar coordinates, discussing the limits of integration and the need for the Jacobian determinant. There are attempts to clarify the bounds for r and θ based on the region of integration.
Participants are actively questioning and refining their understanding of the limits of integration in polar coordinates. Some have suggested plotting the region to better visualize the integration bounds, while others have pointed out potential errors in reasoning regarding the limits.
There are discussions about the specific region of integration, including considerations of the first and second quadrants and the implications of the function being undefined for x > 0. Participants are also examining the relationship between r and θ in the context of the polar coordinate transformation.
IsaacStats
∫∫√(x^2+y^2)dxdy with 0<=y<=1 and -SQRT(y-y^2)<=x<=0
x=rcos(theta)
y=rsin(theta)
0.5<=r=1, we get r=0.5 from -SQRT(y-y^2)<=x by completing the square on the LHS
then, 0<=theta<=pi
But, when I calculated the original integral, I got 0.2222...
When I calculate the integral with the polar coordinates, I get 0.92
Maybe you forgot the determinant of the Jacobian?
Anyway,without taking a look at your calculations,we can't help!
Well,
∫∫(r^2)drdtheta
For clarification,
http://www.math.utsc.utoronto.ca/b41/oldexams/2004ffinal.pdf
q8c
All what is required of me is to change the limits of integration
what I got is:
0<=theta<=pi
0.5<=r<=1
U need a factor of r. da=rdrdtheta
IsaacStats said:
Well,
0<=theta<=pi
0.5<=r<=1
Did you try to plot the region of integration? How did you get those limits?
Explanation:
I started out with the graph. In the first quadrant we have a quarter of a circle x^2+y^2=1 (radius = 1. In the second quadrant we have x^2+(y-0.5)^2=0.25 (radius=0.5). Then, since the function exists both in first and second quadrant, 0<=theta<=pi. Then, by my false reasoning, I made a mistake of thinking that 0.5<=r<=1.
After revising my calculations, I got 0<=theta<=pi/2, 0<=r<=1. I derived the limits for theta in the following way
0<=rsin(theta)<=1
-SQRT(rsin(theta)-(rsin(theta))^2)<=rcos(theta)<=0
rsin(theta)-(rsin(theta))^2=(rcos(theta))^2
sin(theta)=r
Then, by substituting into the first line, we have
0<=(sin(theta))^2<=1
Then, theta1=0, theta2=pi/2
Hence, r1=0, r2=1
Those bounds describe a portion of the unit circle centered on the origin in the first quadrant.
So, to get to the right conclusion do I add the area of the half of the circle centered at (0,0.5)?
Are you sure you are considering the right half of the curve x = ±√(y-y2)? For sure, this exists in both first and second quadrants, but you are only interested in the half x = -√(y-y2). Since √(y-y2) ≥ 0, what quadrant does x=-√(y-y2) lie?
In the second quadrant = > (pi/2)<=theta<=pi
0<=r<=0.5
0<=r<=0.5
I agree on the bounds for θ, but the values for r suggest a circle of radius 1/2 centered on the origin. Consider the curve x2+y2=y. Convert this to polar coordinates and you will obtain r. This value of r will depend on θ.
Thank you for correction. If (pi/2)<=theta<=pi, does it meant that sin(pi)<=r<=sin(pi/2); 0<=r<=1.
that's weird
that's weird
These bounds say that as θ goes from π/2 to π, r goes from 0 to 1. r is measured from the origin and so r is precisely 1 at only one value of θ, namely θ = π/2. (See this from a sketch). So the bounds for r have to depend on θ, otherwise you are describing a portion of the unit circle centered at the origin.
That's great!
Does this mean that we can write the integral as a sum of two integrals (first quadrant circle and second quadrant circle)
0<=theta<=n/2, 0<=r<=1 + n/2<=theta<n, 0<=r<=sin(theta)
OR( 0<theta<n (0<=r<=1 + 0<=r<=sin(theta))
IsaacStats said:
That's great!
Why did you tag on the part '0<=theta<=n/2, 0<=r<=1'? Remember x ≤ 0 so there should be nothing that describes anything in the first quadrant.
The bounds 'n/2<=theta<n, 0<=r<=sin(theta)' describe the required region. Did you draw a sketch? Convince yourself that this is the correct range for r - try out a few values of θ and see that you get reasonable values for r (r should monotonically decrease to 0 as θ sweeps from π/2 to π)
RIGHT! Function is undefined for X>0.
Therefore, n/2<=theta<=n, and 0<=r<=sin(theta)
Yes, everything makes sense?
Out of curiosity, why does not r go between 0 and csc(theta)?
The curve in Cartesians was ##x^2 + y^2 = y##. Converting this to polar coordinates gives ##r^2 = r\sin\theta## from which we see that ##r = \sin \theta##. ##\theta = \pi/2## is the maximum value for ##r##, while ##\theta = \pi## is the minimum. In between, ##r## takes values given by the sine of the angle ##\theta##.
EXCELLENT! THANKS!
I believe my mistake was looking at 0<=rsin(theta)<=1.
Thank You for your help and may numbers be in your favor.
  • · Replies 19 ·
  • · Replies 20 ·
