What is the simplified integral for evaluating double integrals with IBP?
  • Thread starter Thread starter rmiller70015
    Integrals
rmiller70015
∫∫[ye^(-xy)]dA R=[0,2]×[0,3] evaluate the integral.
So I started with some algebra changing the integral to ∫(e^-x)[∫ye^-ydy]dx
I evaluated the y portion first because its more difficult to deal with and wanted to get it out of the way.
I ended up integrating by parts with:
U=y dv=e^-x
Dy=dy v=-e^-x and got
-ye^(-y) - ∫-e^(-y)dy on the interval [0,3] and got -4e^(-3) + 1
This is now a constant, pulled it out of the x integral leaving:
(-4e^(-3) +1)∫e^(-x)dx
The final integral I evaluated as:
-e^(-x) on [0,2] gives
-e^(-2) + e^0 and this is multiplied by the previous number to give:
4e^(-6)-4e^(-3)-e^(-2)+1
Using a calculator to approximate I get a value of 0.692468
The answer in the book is .5e^(-6) + (5\2) which is approximated by a calculator as 2.5012394
I'm doing something wrong and I am wondering if there is a rule I forgot, do I need to integrate by x first and then y?
It is wrong: ##(e^{-x})(ye^{-y})=ye^{-x-y}## instead of ##ye^{-xy}##
ehild
Likes 1 person
I was walking back from the corner store when I realized this, but thank you for confirming it. I had, as another helper once told me "abused the chain rule."
Oh my! Chain rule abuse! Oh Guard -- Guard! Come quickly before he gets away!
Hint: if y was constant, the integrand would be quite simple.
Verty's hint suggest that you do the integration in the other order:
\int_{y=0}^3\left[\int_{x= 0}^2 ye^{-xy}dx\right] dy
You should find that much simpler.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
