Drag coefficient of an object in freefall in air
The discussion focuses on determining the drag coefficient (Cd) of a badminton shuttlecock during freefall for a low-budget project. To find the Cd, it's essential to measure the drag force when the shuttlecock reaches terminal velocity, where drag force equals weight. A suggested method involves using a fish scale or similar device to measure the drag force while the shuttlecock is in motion. By knowing the temperature, speed, and measured force, calculations can be made to derive the Cd. This approach allows for a practical way to estimate the drag coefficient without expensive equipment.
owen.b3zz3r
We are doing a project on the terminal velocity of a badminton shuttlecock and also have to find the drag coefficientof it. The problem that i have is that we are doing this very low budget I.E. throwing the shuttlecock from a window and filming it, now if i am correct to find the Cd we need to know the drag and to find the drag we need to know the Cd can anyone help me find out how to work out either from the method that we used if it is possible at all. thank you Owen Berry
Can you show some work/formulas?
If you drop the shuttlecock from high enough then it will come very close to terminal velocity. At that point the drag force equals weight.
You do it the same way this is done in any wind tunnel. You figure out a way to measure the drag force on the model while it is in the moving air. That way you now only have one unknown, the Cd. Perhaps if you put it at the end of a fish scale or other force measuring hand held device, you can get some crude numbers for the drag force. You would then know the temperature, the speed and the force. From there on out it's simple calculations.
thanks for that fred
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
