Drag torque of rotating cylinder
The discussion focuses on calculating the drag torque acting on a rotating cylinder under dynamic equilibrium conditions. The user seeks to apply the drag force equation, Fd=-(1/2)*Cd*A*p*v^2, where Cd is the drag coefficient, p is the density of water, and v is the linear velocity. A key insight provided is that the drag force calculated does not cause rotation about the cylinder's axis; instead, shear forces acting on the cylinder's surface must be considered. The conversation also touches on integrating forces over the length of the cylinder to derive a solution for the drag torque.
  • Understanding of fluid dynamics, specifically drag forces
  • Familiarity with the drag coefficient and its application
  • Knowledge of torque and moment arm concepts
  • Basic calculus for integration of forces over a length
  • Study the effects of shear forces on rotating bodies in fluid dynamics
  • Learn about boundary layer theory and its implications for drag calculations
  • Explore the integration of forces along a moment arm in mechanical systems
  • Investigate the relationship between impeller diameter and torque/power in fluid mixing applications
Mechanical engineers, fluid dynamics researchers, and students studying rotational dynamics and drag forces in fluids will benefit from this discussion.
FishJaws
Hey folks,
New to the forum and eager to tap the resources of all your brilliant minds.
Here's the problem. I'm modeling a system as a cylinder rotating on its end. Under a dynamic equilibrium situation with an applied force of a known value, I know its angular acceleration and instantaneous velocity.
How would one find the drag torque acting on the cylinder? I know the drag coefficient, area, and angular velocity of course, but need to apply it all to this drag force equation, Fd=-(1/2)*Cd*A*p*v^2,
where Cd is the drag coefficient, p the density of the medium (water in this case), and v the linear velocity.
Do you'll have a differential and derivative you can pull out of the air, something that accounts for the moment arm?
Many thanks!
FishJaws said:
Hey folks,
Many thanks!
The equation you have written for drag is the drag parallel to the flow. That drag force will not cause the cylinder to rotate about its axis nor will it oppose that motion. To determine that force you would need to calculate the shear force acting on the surface of cylinder. So you would need information about the boundary layer around the circumference.
Thanks, Random. Would the same be the case if I modeled the system as a flat plate rotating on end?
I was sure that I could integrate area along the moment arm based on my original equation using the appropriate Cd for the shape. Bummer.
Thanks again.
Thanks again.
Let me first make sure I am understanding you. Do you mean the cylinder will be rotating about its cylindrical axis? Because that what I was referring to in my first post. What exactly do you mean rotating on end?
Ok, so you disregard my previous comments.
I have an idea of how to solve this hopefully it is correct. Basically I calculated the force on a differential element of length dr and then integrated over the length of the cylinder. I have attached my solution. Hopefully it makes sense.
Random, you're a life life saver. This does indeed make sense. Lots of thanks for the help!
  • · Replies 19 ·
  • · Replies 60 ·
  • · Replies 34 ·
  • · Replies 22 ·
