Drive a 12 Ohm, 50mH Transformer Coil with 12V @ 1A
  • Thread starter Thread starter BHY-BK
    Circuit Coil
The discussion revolves around driving a 12-ohm, 50mH transformer coil with a signal generator producing 12kHz square waves at 12V and 1A. Participants suggest using a TO-220 package transistor like the MJE3055 with a heatsink, ensuring sufficient base current for operation. They discuss the importance of incorporating a diode to protect the transistor and explore alternatives like power MOSFETs for better performance. The rise and fall times of the signal are considered, with suggestions to use a buffer if needed, while acknowledging that the generator's output characteristics will influence the switching speed. Overall, the conversation emphasizes circuit design considerations for effectively driving the transformer coil.
BHY-BK
I have a signal generator that is used to generate 12kHz square waves. I want to use my signal generator to drive a transformer primary coil. My coil has 12 ohms resistance, 50mH, and will have 12V applied to it @ 1A.
Can I buy a circuit to drive the coil from the signal generator pulse or do I have to make one?
What is the correct terminology for such a circuit?
Do this:
You can get fancy to drive it with faster edges, or use a power fet instead of a 2n3055, or do a search on coil driver and look at the images for one you like
Likes jim hardy
12 V square wave ? Does it go from 0V to +12V or from -6 to +6 ?
What's the part number of your transformer ? Does it have a small air gap in the core ?
Sorry, it's 0V to +12V, transformer is one a friend made for me, it has a small gap in the core but it's not a flyback. It's a step up transformer with a 1:5 turns ratio.
meBigGuy said:
Do this:
Will my 5V signal from my signal generator be able to drive the 2N3055?
Dumb question I know, it's just been a while since I played around with electronics and I've forgotten a lot.
Probably. Do you have a model number?
Looking at the specs for an MJE3055 in a TO-220 package, it is rated for 0.6W without a heatsink. That's borderline for 1 amp. I'd use the to-220 and add a small heatsink.
Like this http://www.mouser.com/ProductDetail/Aavid-Thermalloy/6237BG/?qs=sGAEpiMZZMttgyDkZ5WiuqcEpFN0QqoQfmtMCSJ6UoA%3d
For 1A, you probably want at least 100ma base current which would be at around 4volts with a 300 ohm resistor. Can your function generator drive 100ma? If it has a 50 ohm output, then no problem.
If there is not enough drive you can go to a 2 stage circuit, or a darlington, or a mosfet. Regardless, a TO-220 package with a clip-on heatsink will be the most robust solution.
Don't forget the diode --- the transistor will blow without it.
Cool, thanks for the suggestions, I'll use them. The function generator is 50 ohms! Any idea how fast the rise and fall time will be?
Would adding a buffer like a 4050 reduce the rise and fall time?
Again, it depends on your generators output. Since you are switching an inductor, the turn-on/off time may not have much effect overall. You can speed up the transistor switching with a very small cap across the 300 ohm, but again, it won't change much. If the 4050 is faster than your generator, then that will help.
If speed is really an issue, then there may be better solutions than the 3055, like a power mosfet and a hefty mosfet driver (mosfets have huge gate capacitance)
There is probably some power mosfet you can connect directly to the generator and drive it without a heatsink or a series resistor.
I found some mosfets in this thread. Maybe that's a better way to go.
https://www.physicsforums.com/threads/electromagnet-and-mosfets.831892/#post-5224970
Likes BHY-BK
What's connected to the secondary of this transformer ?
Connected to the secondary of the transformer is capacitor and resistive load of about 300 ohms
