Driver Car Seat Motion Mechanism
Yaniv is designing a simulator seat that requires motion mechanisms similar to those found in car seats, specifically sliders, recliners, and vertical motion components. He is struggling to find manufacturers for these mechanisms and seeks guidance on their technical names to aid in his search. Suggestions include exploring local boneyards for used components and researching existing driving simulator designs to determine the necessary degrees of freedom (DOF) for his project. The discussion highlights that 2-DOF and 4-DOF systems are common for driving simulators, with varying costs and complexity. Resources like Jegs.com and manufacturers such as Scat are recommended for sourcing components.
Yaniv Mordeha
Hi All,
I'm working on a design of a seat for a simulator, the seat should include the motion mechanisms like the one in a car which Includes the slider, recliner, and the mechanism responsible for the vertical motion of the seat. So my question is
I want to buy these mechanisms and integrate them into my design to save costs and time, however I can't find the companies who manufacture the required components. I searched on the net for 'slider' and 'recliner' however it didn't get me results of manufacturers. Does anyone know the name of the manufacturers of the mechanisms or how can I get them?
Further, with regard to the mechanism responsible for the vertical motion of the seat, my biggest problem is that I don't know the technical name for this mechanism, if someone knows it will be very useful (to locate the manufacturers).
Thanks,
Yaniv
A 'simulator'? What are you trying to achieve by this 'simulator?
Are you simulating the movement of a car seat in a testing capacity, so just testing the acutal seat? Or is this a simulator to train a driver?
Yaniv, one of my favourite sources of motors/activators is power seat mechanisms. I get mine from a local boneyard who occasionally has an "all you can carry out for $25" sale. If such a thing exists in your area, it's worth investigating.
I would look at existing designs for driving simulators before you design anything. You'll need to decide how many degrees of freedom you want, it can range from 2 to 6. The price of the simulator will rise dramatically based on the number of DOF.
Most 2 DOF simulators I've seen basically roll the driver left and right, and tip forward and back. These two DOF's basically simulate acceleration, braking, and turning left/right. A 2-DOF rig is usually pretty easy to put together with a pair of linear actuators (usually electric, pneumatic, or hydraulic cylinders) and a U-joint pivot point. From there, you'll have to keep statics/dynamics in mind if you're wanting more DOF.
A 6-DOF system would be set up with a Hexapod like a flight simulator. Probably overkill for a driving simulator (although there are a few). 2-DOF and 4-DOF are the most common kinds out there, 2-DOF can be <barely> affordable, 4-DOF cost as much as a car, 6-DOF cost as much as a house. Additionally, they're usually application-specific, meaning they only work with 1 or 2 racing games.
www.jegs.com
http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?Ne=1%2b2%2b3%2b1147708%2b1&Ntt=driver+seat&langId=-1&Ntk=all&storeId=10001&Jnar=0&catalogId=10002&N=1010481&Nty=0
good start to find manufacturers..Scat is one
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
