Dropping objects air resistance
The discussion centers on determining the range of gravitational acceleration, g, that allows a creature to survive a fall from height h, given its mass m and surface area A. Air resistance is acknowledged as a critical factor, with the drag force modeled as F_D = -k * v. Participants suggest that solving a differential equation is necessary to relate g to the force threshold F_K, height h, mass m, and surface area A, potentially involving terminal velocity calculations. There is also consideration of the ground's softness affecting the impact force experienced by the creature. Overall, the problem emphasizes the importance of air resistance and the need for careful analysis to ensure the creature's survival.
Big-Daddy
A creature of mass m and bottom surface area of A is dropped from a height h towards the ground. The creature dies if a force of F_K or greater acts on it. What is the value range of acceleration due to gravity, g, for such creature to survive the fall?
Surely the problem requires air resistance since mass and surface area are mentioned. I think this can be modeled as F_D=-k \cdot v unless anyone has any better ideas?
The question is what else to do - we'll need a differential equation, then to solve it for g in terms of F_K, h, m and A (probably work out the terminal velocity first and then relate it to F_K and g)? I hope we can assume that height h is sufficient that terminal velocity will be reached. If not, we might have to use something more fundamental.
Depends on the softness of the ground. Use the impulse formula. F*Δt = Δp and Δt =√(2s/g). But you need to know s, the distance over which the fall was cushioned, i.e. the softness of the ground.
The presence of A in the problem statement does suggest that air resistance was to be considered. Could be a red herring. I would ignore it or get an explanation from the instructor.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
