Dynamics coefficient of friction
To determine the shortest stopping distance and time for a car moving down a 20-degree slope at 33 m/s with a friction coefficient of 0.58, it's essential to calculate the net forces acting on the car. The maximum static friction is given by the formula Fmax = uR, where R is the normal force, which can be expressed as R = mg cos(20) or R = mgsin(70). The mass of the car is not necessary for finding acceleration, as it cancels out in the calculations. The net force acting parallel to the slope includes both the friction force and the component of the car's weight. Understanding these forces will allow for the application of Newton's second law to find the required acceleration for stopping.
polly06
My question is:
If a car is moving at 33m/s^-1 down a 20 degree slope, the friction between car tires and the road surface is 0.58, what is the shortest distance and time in which it can stop?
I assume that Fmax= u R is correct formula?
(where Fmax=force max, u=coeff of friction, and R= normal reaction)
I also assume that R = mgsin20
(where m=mass, g=9.8, sin 20 for angle of slope)
Any help would be much appreciated!
thanks
-Polly
The maximum static friction will be \mu R, but friction is not the only force acting on the car.
Careful. The angle is usually measured from the horizontal (an 0 degree slope is perfectly horizontal) so check your trig.
To find the maximum acceleration of the car, find the net force acting parallel to the slope.
...ok, thank you for your prompt reply Doc Al.
Where I am confused is:
Max static friction = uR
...so how can R be calculated when the mass is unknown?
...so I deduct that it should have been R= mgsin70
...so I now need to determine the net force acting parallel to the slope by deducting the friction forces from the the force produced by the car's mass and acceleration?
I have referred back to my study notes, and to online tutorials, but seem to be missing something here!
Part time studies by correspondance was never meant to be easy!
thanks
-Polly
Just express it symbolically as you've been doing. You'll find that you don't need the mass to find the car's acceleration. (The mass will cancel in your final formula.)
Right. The normal force must balance the component of the car's weight perpendicular to the slope.
There are two forces acting on the car parallel to the slope: The friction, as we've discussed, and a component of the car's weight. The sum of these two (one is negative, of course) gives the net force. Then use Newton's 2nd law to find the acceleration.
It can't- but you don't need that, you only need the net acceleration. If you carry the mass as "m" in the formula you should see that it cancels out at the end.
Yes, or mg cos(20).
Well, you don't want to determine the force "produced by the car's mass and acceleration", you want to determine the acceleration produced by the car's mass and force (force causes acceleration, acceleration does not cause force!).
Actually you are correct that the gravitational force is F= mg where g is the acceleration due to gravitational force. I think that's what you meant but I still wouldn't say that the acceleration "produced" the force. Notice that you will also want to find the component of that down the hill- a little more trig.
..thanks for the replies.
I have booked into see a phyics tutor this week.
I shall reply with my findings
thanks again
-polly
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
