E-B crossed fields parallel plate
unscientific
A parallel plate has p.d. V with one end 0V and the other +V. B-field of strength B has direction along plates. An electron is released from rest at 0V plate. Show that if V is less than e(DB)2/(2m) the electron will not reach the other plate.
At half-way inbetween the plates, the radius must be d/2
R = mv/Bq
d/2 = m*√(2*e*0.5V/m) / (Bq)
I end up with e(DB)2/(4m) instead..
Hello.
I don't follow your statement. Could you just as well reason that when the electron is 3/4 of the way across, then the radius must be d/4? If so, would you get the same answer?
I think you're going to need to set up the equations of motion for the x and y components of acceleration.
TSny said:
Hello.
define x as upwards, y into the plate.
max = eV/d
may = qvB
x2 + y2 = d2
is that right?
Let me make sure I understand your choice of directions and signs. Correct me if I'm wrong. You're choosing the electric field in the negative x direction so that the E field accelerates the electron in the positive x direction. The x-axis is oriented perpendicular to the plates.
y-axis is parallel to the plates and B is parallel to the plates but perpendicular to both the x-axis and the y-axis such that when the electron starts moving the B field begins to deflect the electron toward positive y.
But once the electron is deflected some in the y-direction by the B field, the electron will then have a y-component of velocity. So, the magnetic field will then cause some force parallel to the x-axis! So, you need to include a magnetic force term in your equation for ax.
The electron is going to move along a curved path, so you can't say x2+y2 = d2 (if d represents the separation of the plates).
