Finding Electric Field from Potential: Understanding Why and How
  • Thread starter Thread starter Identity
    Field Potential
The discussion focuses on the relationship between electric potential and electric field, emphasizing that while potential can be zero at a point, the electric field may still be non-zero due to its dependence on the gradient of the potential. It explains that potential is arbitrary and can be offset without affecting the electric field, highlighting the importance of potential difference. The analogy of a function's value and its derivative illustrates that knowing the potential at a single point does not provide enough information to determine the electric field at that point. To accurately find the electric field, a general expression for potential across multiple points must be established, allowing for the calculation of the gradient. Understanding this relationship is crucial for analyzing charge distributions and their effects.
Identity
Say you have a charge distribution in the picture, and you want to find the potential THEN the electric field at P, using E = -\nabla V
I found the potential to be 0, and yet the field isn't. Why is this?
And how would we get the actual field from the voltage?
Potential is arbitrary. It is easy to see, from the relationship that the electric field is the gradient of the potential, that we can give the potential any DC offset and not affect the resulting electric field. What is of true importance for us is the potential difference.
For point charges, it is often simple to set the potential at infinityto be zero. Under such an assumptions, then yes, the potential at point P, or in fact at any point along the z-axis (the dotted line in the picture) the potential will be zero. However, the electric field is related to the gradient of the potential. So just because a function evaluates to zero at a point does not mean that the derivative of the function evaluates to zero at that point as well.
If you were to work out the gradient of the general expression for the potential at any point, then you would find that if you solved for the field at point P it would be non-zero.
Oh, ok, so by analogy, if you find the potential anywhere, it's like finding
f(x), from which you can find f'(x)
However if you find the potential only at 1 point or a set of points, it's like finding
f(x_0), and from that \frac{d}{dx}f(x_0) = 0 since it's a constant?
Is that kinda right?
thanks
Allow me to make an analogy... you know that for a function of a single variable, the derivative at a point is the slope of a graph of the function at that point, right? What you're saying is that if you find the value of a function at only one point, then the slope has to be zero at that point. Does that make sense? :smile:
In order to find the slope at a point, you need to know the values of the function not only at the point in question, but also at neighboring points. Either you know an explicit value at some particular nearby point, in which case you calculate the slope approximately as \Delta y / \Delta x; or you know a formula for the function, in which case you find the derivative of the formula (which gives you the slope at all points) and evaluate it at the point in question.
In this case you have to find a general formula for the potential at all points, and then find the negative gradient of that formula (which gives you the field at all points) and evaluate it at the point in question.
Ah ok thanks jtbell and Born2bwire
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
