E-field of a laser pulse and Intensity
The discussion focuses on deriving the electric field equation for a single laser pulse and its intensity as a function of frequency when measured by a square law detector in a grating spectroscope. The user acknowledges the relationship between energy and the electric field, noting that intensity is typically calculated using the equation I = 1/2 Epsilon * c * E^2, which does not incorporate frequency dependence. A key point raised is the general independence of frequency and intensity, questioning the expectation of a relationship between the two. The conversation emphasizes the need for clarity on how intensity can be expressed in relation to frequency in this context. Understanding these principles is crucial for accurate measurements in laser applications.
PhysMaster
Hi,
What is the equation for a E field of a single pulse of a laser?
If that laser is shined onto say a grating spectroscope (square law detector), how can I go about deriving an expression for Intensity as a function of frequency at the output of the spectroscope?
I know that the square law detector will measure Energy which is the square of the E field (and some proportionality factor that I don't know).
I also know Intensity equation, I = 1/2 Epsilon * c * E^2 where Epsilon is the permittivity in vacuum. But that doesn't seem to apply here since it has no dependence on frequency.
Any help is much appreciated.
Science news on Phys.org
Frequency and intensity are independent of each other, in general. Why do you think there should be a relationship between them?
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
