Solving an E-Field Question: Magnitude of Electric Field Calculation
  • Thread starter zath
  • Tags
    E-field
In summary, the conversation discusses a question about the magnitude of the electric field at a specific point on the x-axis due to a charge distribution along the same axis. The solution involves using Coulomb's law and the superposition principle to calculate the electric field due to infinitesimal pieces of the line of charge. The calculated value is in N/C or V/m, which are equivalent units.
zath
[SOLVED] E-field question
I'm new here but hope that's not a problem. I have an e-field problem that i was wondering about. Now this is how it was presendetd to me.
A charge of uniform density 4.0 nC/m is distributed along the x-axis from x=-2.0 m to x=+3.0m. What is the magnitude of the electric field at the point x=+5.0m on the x axis?
this is a fealer quesition. i have some outers but i sort of whant to test this system if you will.
Hi zath,
Welcome to PhysicsForums. :smile:
Can you evaluate an integration of Coloumb's Law over the line of charge?
- Warren
lambda = 4e-9 C/m
x1=-2, x2=3, x=5 m
Q=lambda/x = 0.8e-9 C = 800pC
...so you have an line charge streched from x1(-2,0) to x2(3,0). that charge produces an uniform electric field with vector x from x1 and x2, and vector y 0. if you want to measure electric field in y(5,0), there is no electric field there, because there is no charge there.
welcome to the forums
What?
You better think about this some more.
Oh? Why would that be?
It is true that for an infinitely long line of charge, the E-field will have no component parallel to the line, but this line of charge is NOT infinitely long.
First, let's do a sanity check. Let's say all 20 nC of the charge was concentrated at the origin, and calculate the field due to it 5 m away.
E = 1 / (4 pi e0) * q / r2
= 7.19004 N/C = 7.19004 V/m
So our answer to this question should be roughly this size -- if its end up way bigger or way smaller, we probably made a mistake.
Let's break the line of charge up into infinitesimal pieces, and sum the fields due to each piece. This is the superposition principle -- the field due to a number of charges is the simple sum of each of the charges considered in isolation.
Let's call a little piece of the line ds. How much charge, dq, is on that little piece of line? Simple. dq = [lamb] ds.
How far is that little piece of the line from our measurement location at x = 5? Simple, r = 5 - s.
What's the field due to the charge dq on that little piece of the line? It's
dE = 1 / (4 pi e0) * [lamb] ds / (5 - s)2
Notice that I've subsituted the expressions for dq and r that I discovered above.
What's the field due to all the little pieces of the line summed together? It's an integration of the field contributed by each piece of the line, over the length of the line, like this:
E = Integral (from s = -2 to s = 3) of 1 / (4 pi e0) * [lamb] ds / (5 - s)2
Doing the integral and plugging in the limits of integration gets me 12.8394 N/C = 12.8394 V/m.
You can assume from symmetry that this field is directed along the positive x-axis, away from the line of charge.
Does this make sense?
- Warren
omg...sorry, i mis-read. i tought it said 5,0 on y axis.
There'd be a non-zero E field there, too!
- Warren
how if the line charge is developed on the x axis? if volume charge is developed then it wouldn be zero...
Even a point charge has a spherical field, right?
Chroot
thank you very much, you got my question answerd very well (sorry that I'm so long in replying). One question for you. When i do the integration i gt et the same 12.8394 and there is no question about that. When i do it long hand i get some funny units that didnt match yours, so i envoked the power of TI and punched the units into the equation as well, and i ether get only V, or i get T/s. i get voults if i leave the (5-s) demenstionless and i get the T/s if i put the (5-s) as m. What am i doing wrong??
Originally posted by zath
Chroot
Coulomb's law involves the following units: e0 has the units C2/J-m; q has unit C; r has unit m.
Combining,
E (N/C) = 1/4 pi e0 [J-m/C2] * q/r2 [C/m2]
Cancelling the units, you'll see that E is indeed in J/m-C, where a J/m is the same as Newtons. The E field is indeed N/C.
You can see how N/C = V/m by considering the units of electrical potential. You can see in the expression
V = (1/4 pi e0) (q / r)
that potential has units of J/C.
Furthermore, since force has units of J/m, you can see quickly that N/C and V/m are the same unit.
- Warren
1. What is an electric field?
An electric field is a measure of the force exerted on a charged particle by other charged particles in its surroundings. It is represented by a vector that points in the direction of the force.
2. How do you calculate the magnitude of an electric field?
The magnitude of an electric field can be calculated using the equation E = F/q, where E is the electric field, F is the force exerted on the charged particle, and q is the charge of the particle.
3. What factors affect the magnitude of an electric field?
The magnitude of an electric field is affected by the distance between the charged particles, the charges of the particles, and the medium through which the electric field exists.
4. What units are used to measure the magnitude of an electric field?
The magnitude of an electric field is typically measured in newtons per coulomb (N/C) or volts per meter (V/m).
5. How is the direction of an electric field determined?
The direction of an electric field is determined by the direction of the force on a positive test charge placed in the field. The field lines always point away from positive charges and towards negative charges.
