Earth Orbits of Geostationary Satellites
The discussion revolves around the movement of geostationary satellites in relation to the Earth's orbit and their behavior in different reference frames. Participants explore the definitions and implications of geostationary versus geosynchronous satellites, as well as the practical aspects of satellite communication.
  • Some participants clarify that geostationary satellites orbit the Earth once a day and remain stationary relative to a point on the Earth's surface, but they also move with the Earth in its orbit around the Sun.
  • There is a suggestion that textbooks may misrepresent the motion of geostationary satellites by stating they do not move at all, which has caused confusion among some participants.
  • One participant notes that movement is dependent on the chosen reference frame, indicating that from a solar system perspective, all Earth satellites follow complex paths.
  • It is mentioned that geostationary satellites oscillate slightly north and south of a fixed point on the Earth's surface, and they rotate with the Earth.
  • Participants discuss the implications of satellite motion on communication technology, emphasizing the importance of geostationary satellites for fixed dish antennas used in satellite TV and other communications.
  • There is a historical reference to early satellite communications, highlighting the challenges faced before the advent of geostationary satellites.
  • One participant raises a question about the technical challenges of using steerable antennas if satellites were not geostationary.
Participants generally agree that geostationary satellites do move, but there is no consensus on the clarity of textbook explanations regarding their motion. Multiple viewpoints on the implications of satellite movement and communication technology are present.
Some statements reflect assumptions about the clarity of definitions and the impact of reference frames on the understanding of satellite motion. The discussion includes nuances regarding the technical aspects of satellite communication and the historical context of satellite technology.
John12343210
Do geostationary satellites move with the Earth's orbit or do they not move at all?
Astronomy news on Phys.org
Are you asking for the difference between geosynchronous and geostationary satellites?
no
What do you mean, then? All satellites move in some sense or other, including geostationary ones.
Geostationary satellites orbit the Earth once a day, remaining stationary in a rotating reference frame centered on Earth. Clearly they must also follow the Earth through its orbit around the sun, as all satellites do.
Both they and all other satellites, including the Moon, move with the Earth around the Sun.
thanks guys, some of my textbooks were saying geostationary satellites don't move at all, so I was a bit confused
What your textbooks are probably saying is that they do not move (significantly) relative to any "fixed" point on the Earth's surface. It sounds as if they weren't saying it very well.
John12343210 said:
...some of my textbooks were saying geostationary satellites don't move at all...
Movement depends on the used reference frame. Make sure that you read precisely what the book says.
For instance for a (center of mass) observer of the solar system all Earth satellites actually travel "open" spiral serpentine paths about the Earth's orbit!
They do oscillate a little north and south of a fixed point on the Earth's surface
Other than that, they rotate with the Earth. If they didn't, Satellite TV and other comms wouldn't be possible through themDave
Let me be pedantic and amend your comment to, "If they didn't, Satellite TV and other comms would be much more difficult to implement continously through them".
Early transatlantic television transmissions were made on two Telstar satellites in the early 1960s. These satellites had an orbital period of a couple of hours, so that transmissions lasted for only twenty minutes at a time and required the transmitting and receiving antennas to be continuously redirected.
I especially recall the transmission of a portion of the funeral of President Kennedy. Today we are accustomed to HD transmissions, in colour on 48" screens. Viewing the shaking image of the funeral cortège in black and white, on an 18"screen, with only 405 lines, strengthened the pathos and impact of the event.
Also, @John12343210, in regard to your original question, gravitational forces are continually tending to move the satellites out of position so that thrusters must be used to counteract this tendency. I understand the fuel load is what generally determines the effective lifetime of such satellites. The process is known as station keeping.
Impossibly difficult as you wouldn't be able to use the fixed dishes that are currently used, you would be chasing the sat's all over the sky with signals coming and going as you tried to watch your fav movie or sports channel etc
The only people that like chasing sat's around the sky are amateur radio operators like myselfD
Surely, so expensive as to be impractical, would be the more accurate description? Or, if you prefer, the equivalent, but more potent, practically impossible.
That said - at the risk of moving off topic - would the circuitry to adjust a steerable antenna responsive to signal strength be especially challenging? Or, given that the track of a given satellite would be known within reasonable limits coarse tracking could follow that, supplemented by feedback in signal strength.
  • · Replies 36 ·
9K
  • · Replies 22 ·
  • · Replies 19 ·
