Earth's gravitational field strength
The discussion focuses on calculating the altitude above Earth's surface where gravitational field strength is reduced to two-thirds and one-third of its surface value. Using the formula F = GMm/r², participants clarify that the mass of the second object is irrelevant as it cancels out. The correct approach involves setting the gravitational acceleration at the desired altitudes to 9.8 m/s² divided by the respective fractions, then solving for the radius, which includes the Earth's radius (6.371 x 10³ km) plus the altitude.
  • Understanding of gravitational force and acceleration concepts
  • Familiarity with the formula F = GMm/r²
  • Knowledge of proportional reasoning in physics
  • Basic algebra skills for solving equations
  • Study the derivation and applications of the gravitational force formula F = GMm/r²
  • Learn about gravitational field strength variations with altitude
  • Explore the concept of proportional reasoning in physics problems
  • Practice solving problems involving gravitational acceleration and altitudes
Students studying physics, educators teaching gravitational concepts, and anyone interested in understanding the effects of altitude on gravitational field strength.
D4b34r5
(a) Find the altitude above the Earth's surface where Earth's gravitational field strength would be two-thirds of its value at the surface. Assume re = 6.371 multiplied by 10^3 km.
wrong check mark km
(b) Find the altitude above the Earth's surface where Earth's gravitational field strength would be one-third of its value at the surface.
wrong check mark km
[Hint: First find the radius for each situation; then recall that the altitude is the distance from the surface to a point above the surface. Use proportional reasoning.]
F = GMm/r^2
I have tried it and I am either calculating wrong or setting it up wrong... or both. One problem I see with the formula is that it doesn't have the mass of the second object.. so I don't know what to do there.
you do not need to know the mass of the second object. F=ma and the masses of the second object cancel out. a=9.8m/s^2 on Earth and at the point above the Earth a=9.8/3 let r=radius of Earth + altitude. then plug in and solve for a.
Sorry but that still isn't helping me. Are you just using the F=ma formula?
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 17 ·
34K
