What is the Hamiltonian for a bead on a rotating rod with fixed z and R?
  • Thread starter Thread starter gluon1988
    Hamiltonian
gluon1988
A bead of mass, m is threaded on a frictionless, straight rod, which lies in the horizontal plane and is forced to spin with constant angular velocity, \omega, about a fixed vertical axis through the midpoint of the rod. Find the Hamiltonian for the bead and show that it does not equal T+U
\mathcal{L}=T-U
\frac{d}{dt}\frac{\partial\mathcal{L}}{\partial\dot{q}}=\frac{\partial\mathcal{L}}{\partial{q}}
p=\frac{\partial\mathcal{L}}{\partial\dot{q}}
\mathcal{H}=\sum p_{i}\dot{q}_{i}-\mathcal{L}
The bead is threaded onto the road, so the radius is fixed. So is the z-axis. The only degree of freedom for the bead is \phi, the angle it is located at in reference to a starting point.
\mathcal{L}=\frac{1}{2}m(\dot{\phi} R)^{2}-U(\phi)
p=\frac{\partial\mathcal{L}}{\partial\dot{\phi}}=m{R^2}{\dot{\phi}}
\mathcal{H}=m{R^2}{{\dot{\phi}}^2}-\frac{1}{2}m(\dot{\phi} R)^{2}-U(\phi)=\frac{1}{2}m(\dot{\phi} R)^{2}+U(\phi)\rightarrow\mathcal{H}=T+U??
I'm assuming I am getting the kinetic energy wrong but I really don't see what it could be with z and R fixed. Please help
Huh, I don't see any physical reason why H≠T+U. The two conditions seem to be met: the system is conservative (potential energy is velocity independent), and the equations of transformation connecting the rectangular and generalized coordinates are independent of time.
While it doesn't change the two points I listed above, why are you saying that z does not change? Seems to me like z is able to change.
The problem just stated that H≠T+U. I think they were trying to show that not every form of general coordinates will work for non-inertial frames. Regardless, I was missing a term of {{\omega}^2}{sin}^{2}(\phi){\phi}^2 in the kinetic energy term, which does in fact lead to H≠T+U.
The problem was listed on the easier section of the text, so I assumed they weren't going to vary z, which they didn't thankfully.
Thanks for the reply
Oh, I see now what the problem was describing. It's written in the usual cryptic, non-explicit description that classical mechanics problems tend to have.
The equations of transformation connecting the rectangular and generalized coordinates are not independent of time after all.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
