Easy way of checking for matrix invertability?
  • Thread starter Thread starter rayver
    Matrix
To check for matrix invertibility efficiently, LU factorization is a common method, but it may not be the fastest for repeated calculations. An alternative approach involves examining the linear independence of unit base vectors, although this may lead back to determinant calculations. The Singular Value Decomposition (SVD) method, while accurate, is computationally heavier than LU factorization. The discussion also highlights that for block matrices, specific properties such as norms can provide insights into invertibility. Overall, finding a significantly faster method remains a challenge.
rayver
Hi everyone,
I'm designing a particular algorithm and part of it requires to check if a given Matrix is invertible or not. Computation of the actual determinant is not necessary.
So far I've been doing it with a LU factorization, and then checking for zeros in the diagonal of matrix U, but I was wondering if there is a computationally easier way of doing it. I need to run my algorithm many times (possibly billions) so the less steps it takes the better.
Any ideas?
By the way, just so you know, the algorithm uses only binary matrices (their elements are only 1s and 0s) and matrices full of zeros are allowed.
Thanks.
Daniel @EPFL
Mathematics news on Phys.org
Well, I'm not sure you <i>can</i> determine invertibility of a matrix much faster than you already have tried, but here's a thought:
Since a non-invertible matrix essentially has a reduced span, you might possibly devise an algorithm to check whether the images of unit base vectors forms a linearly independent set or not (the latter implying non-invertibility).
However, this is most likely ending up calculating the determinant rather than being a step in the right direction...
Thanks, I sort of tried that already by calculating the rank of the matrix through the Singular Value Decomposition method and then comparing it with the size of the matrix. As it turns out, the SVD algorithm is computationally much heavier than the LU algorithm.
I wonder if there exist some sort of theorem or identity that might help me with this.
Also, the matrix is a block matrix, this is, it is a square matrix of size 2K composed of 4 smaller matrices of size K. Is this any useful?
C´mon mathematicians, don´t dissapoint me!
Daniel @EPFL
I - B is invertible if ||B||&lt;1 where ||B|| = \sqrt{ \sum_{i=1}^{m} \sum_{j=1}^{n} |b_{ij}|^2} is the Matrix Norm, and the Inverse will be given by (I-B)^{-1} = \sum_{k=0}^{\infty} B^k
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
