Can Transfer Air Effectively Cool a Small Server Room?
In summary, an air conditioner may be the most economical and efficient way to cool a server room, but it may not be as environmentally friendly as using outside air.
Samj008
Hi there,
I need to prove to an architect that the most economical and efficient way to cool our server room will be with an Airconditioner.
At present we have a system which is supposed to recycle the warm air downstairs suring winter and Outside during summer, only it doesn't draw nearly enough air to keep the server room cool.
The room is 1.1M x 1.8M x 2.5M and the machinery inside is producing roughly 5,000 BTU P/hr. The room temperature at the moment is getting up to 30 plus degrees C on mild days with the door wide open (I Dare not close the door to test)
The architecht wants to drill a whole in the floor and allow the marginally cooler air in from below, possibly putting another fan in the floor to provide more flow.
My argument is that the amount of flow required to cool that room to what is necissary using fans and electricity is going to outway any supposed environmental benifit from not using Air Conditioning, however I need to prove that.
Is there a calculation for the amount of air needed to cool a room that size where that much heat is being produced??
Cheers for your help in advance.
Sam
It's a simple first law of thermodynamics problem. You basically have an open system where 5,000 BTU/hr of heat is being added and needs to be removed my a mass flow of air in order to reach a steady state temperature.
The first step is to determine the mass flow rates of air required to remove the heat from the server from both the hole in the floor and the air conditioner. The mass flow rate of the air from the AC will obviously be less than that coming from the hole in floor because its probably going to be at a lower temperature (peak efficiency).
Then its basically just comparing the electrical and capital costs of the fan and AC unit to see which one is cheaper. For this you will need to find the power consumption of the fan and the AC unit and probably include maintenance costs as well.
BTW, AC units are expensive and suck up a lot of juice, so don't be surprised if a hole in the floor with a fan is considerably cheaper.
Whats the outside temperature where you are?
It's a lot cheaper (economically and environmentally) to just move a lot of outside air than to cool it.
Then take a look at the layout of your systems and the airflow.
Do you have racks full of servers with fans blowing out of the back straight into a wall?
Adding ducting and fans to get the best airflow around the machines is better than just overcooling everything.
It is almost always cheaper to use transfer air than to cool air, if the required delta-T isn't too low. What you need to do is use the temperature requirements of the equipment to dictate the answer to the problem. If, for example, the air downstairs is at 75F and your maximum allowable temperature is 78F, then you need 5000/1.1/(78-75)= 1500 CFM.
That said, it is typical for network closets to require the air be cooler than occupied spaces, so using transfer air would be out of the question in that case.
1. How does an eco cooling system work in a small server room?
An eco cooling system in a small server room works by using outside air to cool the room instead of traditional air conditioning units. The system pulls in fresh air from the outside and circulates it through the room, removing heat from the servers and exhausting it back outside.
2. What are the benefits of using an eco cooling system in a small server room?
There are several benefits to using an eco cooling system in a small server room. These include reduced energy consumption, lower operating costs, and a more environmentally friendly solution compared to traditional cooling methods. It can also help to improve the lifespan and performance of servers by maintaining a consistent temperature and humidity level.
3. Are there any maintenance requirements for an eco cooling system in a small server room?
Like any other cooling system, an eco cooling system in a small server room will require regular maintenance to ensure it continues to function efficiently. This may include changing filters, cleaning the system, and checking for any potential issues. It is important to follow the manufacturer's recommended maintenance schedule to ensure optimal performance.
4. Can an eco cooling system be used in a small server room with a high server density?
Yes, an eco cooling system can be used in a small server room with a high server density. However, the system may need to be customized or scaled up to accommodate the additional heat load from the servers. It is important to consult with a professional to determine the appropriate size and configuration of the eco cooling system for your specific server room needs.
5. Is an eco cooling system suitable for all types of small server rooms?
An eco cooling system can be suitable for most types of small server rooms, including those with limited space or unique layouts. However, it is important to consider factors such as server density, location, and climate when determining if an eco cooling system is the best solution for your specific server room. Consulting with a professional can help determine the most suitable cooling system for your needs.
  • Mechanical Engineering
  • Other Physics Topics
  • Classical Physics
