Effect of EMF in a wire as opposed to a metal chassis?
The discussion centers on the effect of a pulsating DC current in a wire next to another wire and its interaction with a metal chassis. The induced current in the second wire is compared to that in a chassis, with eddy currents being a key focus. It is noted that the large area of the chassis results in lower resistance, leading to a smaller voltage difference compared to a parallel wire. Additionally, at radio frequencies, the conductive chassis acts as a mirror, reflecting currents and reducing the induced current in nearby wires. Overall, the presence of a chassis alters the behavior of induced currents significantly.
Planobilly
Hi,
Consider a wire with a pulsating DC current next to another wire. The expanding and contraction magnetic field induces a current into the second wire.
Consider the same but in the second case we have a metal chassis. I assume the same magnetic field is inducing a current into the chassis.
Is the induced current dissipated as a function of the large metal chassis and if so how? Are there other considerations?
Thanks,
Billy
The effect is usually called a eddy current. Pulsating DC is no longer simply DC, it has a fundamental component and harmonics. For a non-zero conductance it generates heat and electromagnetic forces.
Likes davenn
yes, think, iron core of a transformer
The same current will be induced in the chassis as in a single parallel wire. But the relatively large area of the chassis means that it has a much lower resistance than a wire, so Ohms law says a much lower voltage difference will appear along the chassis than would appear along a parallel wire.
At radio frequencies a conductive chassis makes an excellent mirror. The current in a wire near the “ground plane” sees it's own reflection behind that reflective surface, but with a current flowing in the reverse direction.
A “third” wire near a ground plane will be affected by both the “first” wire and by it's reflection with the opposite direction current. The current induced in a third wire will therefore be less in the presence of the chassis than with the first wire alone.
Likes Planobilly and Bandit127
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
