Effect of Mass and Force on Acceleration and Distance Traveled in Kinematics
  • Thread starter Thread starter Karajovic
    Kinematics Ratio
Doubling the mass of a body while increasing the applied force five-fold results in an acceleration increase of 2.5 times. This is derived from the equation xa = 5f/2m, leading to x = 5/2. Consequently, the distance traveled in a given time also increases by 2.5 times, as shown by the relationship d = 0.5at². The consistent factor of 1/2 in the distance formula confirms that the distance is directly proportional to the acceleration. Overall, both acceleration and distance traveled are significantly affected by the changes in mass and force.
Karajovic
[Solved] Kinematics ratio problem
A force F produces an acceleration a when applied to a certain body. If the mass of the body is doubled and the force increased five-fold, what will be the effect on the following?
a. its acceleration
b. the distance the body travels in a given time
a. i know its acceleration is increased by 2.5 because if we have xa = 5f/2m, x=5/2
b. i know the distance is increased by 2.5, because everything else remains unchanged... but i can't seem to explain it in using equations... d = v1*t + 1/2at^2, if everything remains unchanged except a, we get: xd = 1/2(5/2a)1t^2 (assuming your velocity is 0 m/s?) i get that x = 5/4 but i know that's wrong, the distance can't be increased by 5/4... :confused:
a. its acceleration
Remember that the 1/2 factor is there regardless if the acceleration is changed or not.
d1 = 0.5at2
d2 = 0.5(2.5a)t2 = 2.5(0.5at2) = 2.5d1
d1 = 0.5at2
Thank you very much!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
