Effect of Two Springs on an Object
  • Thread starter Thread starter jemstone
    Springs
The discussion focuses on the effect of using two identical springs to launch a block compared to using one spring. Initially, there is uncertainty about how the speed of the block, denoted as v0, would change with two springs, with a suggestion that it could be 2v0. Participants are encouraged to apply relevant physics equations, including those for spring force and kinetic energy. Ultimately, it is concluded that the block's speed when launched with two springs is actually √2 times v0. This highlights the importance of understanding energy transfer in spring systems.
jemstone
The spring in the figure (link 1) (a)is compressed by length \Deltax. It launches the block across a frictionless surface with speed v0. The two springs in the figure (link 2) (b) are identical to the spring of the figure . They are compressed by the same length \Deltax and used to launch the same block. What is the block's speed now?
picture1: http://session.masteringphysics.com/problemAsset/1000762/5/knight_Figure_10_38a.jpg
picture 2: http://session.masteringphysics.com/problemAsset/1000762/5/knight_Figure_10_38b.jpg
Fsp = -k\Deltas
Us = 1/2 k(\Deltas)2
K = 1/2 mv2
I'm not sure what the effect of two springs would be, but in terms of V0 I feel like it might be 2V0, but that seems to easy.
Try making some substitutions using the equations you quoted to see if your feeling is right or not.
What do you think happens to the force on the block?
Ok I figured it out! I plugged in all the numbers and found that it is sqr(2)v
thanks!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
