Effective Friction Related to Pulley Radius (Atwood Machine)
The discussion centers on an experiment involving an Atwood machine, where the effective friction on a graduated pulley is measured as the radius increases. The participant has derived an equation suggesting that effective friction is inversely proportional to the square of the pulley radius. There is a focus on the relationship between mass, acceleration, and friction, with the participant seeking confirmation of their reasoning. Additionally, the impact of rope bending resistance on pulley friction is raised as a potential factor in the experiment. The overall aim is to validate the derived relationship and the assumptions made during the lab process.
Turkus2
First time posting on the forum - I've been coming here a lot the past year or so to seek answers. This one is concerning a lab. I think I've already done the legwork but am sort of looking for either something I'm missing or a confirmation of sorts. It's pretty messy and wordsy but if you have an answer, cool. If not, tell me to scram and I probably will.
So the lab involves an Atwood machine. We are using a constant mass throughout the experiment on a graduated pulley. We put together our equation for effective friction and calculate it for each setup. Shocking, the effective friction drops precipitously (some might say... exponentially) as the radius of the pulley increases.
A question that's hinted at but only just (quite common in this class) is the relationship between the two. I'm fairly certain I've boiled the equation down to:
Ffriction = a(mass1 + mass2) + g(mass2 - mass1) - (2*i*d)/r2t2
We haven't covered inertia yet - so the i above is a given constant and the d value is the distance the heavier mass drops (which if plugged into the position equation and solved for, produces 1/2at2)
Now... I think I have worked out that if the mass is constant throughout and one assumes the acceleration can be made to be constant throughout (by maneuvering some mass from one side to the other - but keeping the total mass of the system constant), and by plugging in the position equation value for d - the equation simplifies to Ffriction = k(1/r2). Or, the radius and friction are inversely proportional.
Christ, that was a long way to walk to ask... are the square of the radius and the effective friction of the system inversely proportional?
Thank you for reading. This was practically a blog post.
:welcome:
I'm not sure I understand your question. It sounds like you did experiments, and then used curve fitting to match the data to a function. Now you ask if that is the right function; is that your question? Also if you ask about inertia, then the experiments involve speed, nut just static friction; correct?
I always thought that the thing that dominated pulley friction versus radius was the resistance of the rope or cable to bending/unbending. A steel cable has more bending resistance than a rope, and a twisted rope more resistance than a braided rope. Did you include that in your experiments?
anorlunda said:
:welcome:
Thanks for the response. The class is a little unorthodox (i think) in that we are given a vaguely written lab manual and then we design it ourselves. We are basically asked to have everything prepared to perform the experiment and pump out the report in a 2.5hour class. The process of conceptualizing the data deduction and formatting the presentation is the tedious part.
All that said - we are really measuring the effective friction of the pulley on its axle. The inertia is given and while we can move weights from one pulley to the other, the system's entire mass remains constant. I conclude that based on that and the availability of small enough masses, we could make the acceleration constant - which would develop the relationship between the two - inverse square law.
But I'm rambling now. Hope that helps.
OK, I understand your approach. Do you have a question for PF?
I think I'm just verifying that my reasoning is sound, specifically related to how I'm considering the constants.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
