EFields of Insulating hallow sphere around conductive hallow sphere
  • Thread starter ParoXsitiC
  • Tags
    Sphere
In summary: Also, you need to account for the different charge densities in the insulator and conductor.In summary, the problem involves an insulating hollow sphere with a non-uniform charge density and a concentric conducting shell with a net charge. The inner and outer electric fields for both spheres are found using the equations for electric flux and charge enclosed. The potential difference is also calculated for different ranges of r. However, there were some errors in the solution, such as using the wrong surface area for the Gaussian surface and not considering the varying electric field and charge densities.
ParoXsitiC
58
There is a insulating hollow sphere of radius who's inner radius is 0.04 m and outside radius is 0.08 m. It's density is not uniform and is represented by [itex]\rho = 0.0211 \mu C / m^{3.5} * \sqrt{r}[/itex]. It has a net electric charge of +10.0 microC. There is a concentric conducting shell of inner radius 0.12 m and outer radius 0.16 m. It's net electric charge is -20.0 micro C
Find the inner and outer electric fields of both spheres
[itex] \Phi = \oint \vec{E} \cdot d\vec{a} = \frac{q _{enclosed}}{\epsilon _{0}}[/itex]
[itex]E = \frac{q _{enclosed}}{\epsilon _{0}}*\frac{1}{A}[/itex]
[itex]\epsilon _{0} = 8.85 * 10^{-12}[/itex]
[itex]q _{enclosed} = \int \rho dV[/itex]
[itex]A _{1} = 2\pi r = 2\pi(0.04m) = 0.08m\pi[/itex]
[itex]A _{2} = 2\pi r = 2\pi(0.08m) = 0.16m\pi[/itex]
[itex]A _{3} = 2\pi r = 2\pi(0.12m) = 0.24m\pi[/itex]
[itex]A _{4} = 2\pi r = 2\pi(0.16m) = 0.32m\pi[/itex]
[itex]E_{1} = \frac{0}{\epsilon _{0}}*\frac{1}{0.08m\pi} = 0[/itex]
[itex]E_{2} = \frac{10 \mu C}{\epsilon _{0}}*\frac{1}{0.16m\pi} = 2.25 MN/C[/itex]
[itex]E_{3} = \frac{10 \mu C}{\epsilon _{0}}*\frac{1}{0.24m\pi} = 1.50 MN/C[/itex]
[itex]E_{4} = \frac{-20 \mu C}{\epsilon _{0}}*\frac{1}{0.32m\pi} = -2.25 MN/C[/itex]
I thought the outside of the insulator should be equal to inside of conductor that somehow the A won't matter?
Also I wasn't sure if "net charge" meant the just conductor itself has a net charge of -20 uC [thus q enclosed= 10 uC (insulator) - 20 uC (conductor)= -10 uC] or if "net charge" meant all charges added up (10 uC + -30 uC = -20 uC)-----------------
Using the same example, find the potential difference in KV for the following ranges
0 < r < 0.04 m
0.04 m < r < 0.08 m
0.08 m < r < 0.12 m
0.12 m < r < 0.16 m
0.16 m < r < infinity
potential difference = [itex]ΔV = - \int \vec{E} \cdot dr = -E \int_{r_{intial}}^{r_{final}} dr = -E Δr[/itex]
What's the formula for area A1 etc. again?
A1 is just the area of the Gaussian surface, which I believe in this case would be 2 * pi * radius in the
[itex] \Phi = \oint \vec{E} \cdot d\vec{A}[/itex]
Since we picked a surface that E is constant we can pull it out:
[itex] \Phi = \vec{E_{1}} \cdot \int d\vec{A_{1}}[/itex]
[itex] \Phi = \vec{E_{1}} \cdot \vec{A_{1}}[/itex]
[itex] \Phi = E_{1} * A_{1} * cos (0) [/itex]
[itex] \Phi = E_{1} * A_{1} [/itex]
Set [itex] E_{1} * A_{1} [/itex]equal to [itex]\frac{q _{enclosed}}{\epsilon _{0}}[/itex] and get E by itself:
[itex]E_{1} = \frac{q _{enclosed}}{\epsilon _{0}}*\frac{1}{A_{1}}[/itex]
Mmm.. I think i was suppose to use the surface area of a sphere and not a circle. 4*pi*r^2 and not 2*pi*r
Good bet!
Is it being setup right for the most part? Ignoring the Area mistake
The question says "radii of 0.4m and 0.8m" yet then you talk about radii of 0.04m and 0.08m. Which is it?
Sorry I typed the question from memory. It was 0.04 and 0.08.
Your approach is close, but not quite right. The electric field is going to vary with r. You should be finding E(r), not constant values.
1. What is an EField?
An EField, or electric field, is a region in which an electric charge experiences a force due to the presence of other charges. It is a fundamental concept in electromagnetism and is represented by electric field lines.
2. What is an insulating hallow sphere?
An insulating hallow sphere is a spherical object made of a material that does not conduct electricity, such as rubber or plastic. It is used to contain and isolate electric charges within the sphere.
3. What is a conductive hallow sphere?
A conductive hallow sphere is a spherical object made of a material that allows the flow of electric charges, such as metal. It is commonly used as a conductor in electrical circuits.
4. How does the EField of an insulating hallow sphere around a conductive hallow sphere differ from other EFields?
The EField of an insulating hallow sphere around a conductive hallow sphere is unique because it is affected by both the electric charges within the conductive sphere and the insulating material surrounding it. This creates a combination of both radial and tangential electric field lines.
5. What are some real-world applications of EFields in insulating and conductive hallow spheres?
EFields in insulating and conductive hallow spheres are used in various applications such as in capacitors, electrostatic generators, and high-voltage equipment. They are also used in research and experiments to study electric fields and their effects on objects and materials.
