logic smogic
- 54
Problem
A one dimensional particle of mass m and charge q moves on a circle of radius R. A magnetic field pierces the circle. The total magnetic flux through the circle is
\Phi = B \pi R^{2}.
Determine the ground state energy E_{0} (\Phi) and show that it is periodic with period \Phi_{0} = \frac{h c}{q}, called the magnetic flux quantum.
Attempt at Solution
One can use
B = \nabla \times A
and
\Phi = \int B \cdot da = \oint A \cdot dl
to evaluate the vector potential A on the circle. Using a gauge in which A is rotationally symmetric and points in the azimuthal direction,
A = \frac{B R}{2} \hat{\phi} = \frac{\Phi}{2 \pi R} \hat{\phi}
where R is the fixed radius of the loop. The time-independent Hamiltonian for a charged particle in a magnetic field is
H = \frac{(p - \frac{q}{c} A)^{2} }{2m}
Since the motion is 1-dimensional on the circle, the only degree of freedom is x = R \phi, with conjugate momentum,
p = -\imath \hbar \frac{\partial}{\partial x} = - \imath \hbar \frac{1}{R} \frac{\partial}{\partial \phi}
Inserting this and the Hamiltonian into the time-independent Schrodinger Equation yields:
\frac{1}{2m} ( -\frac{\imath \hbar}{R} \frac{\partial}{\partial \phi} - \frac{q}{c} \frac{\Phi}{2 \pi R} )^{2} \psi (\phi) = E \psi (\phi)
Question: Noting that this resembles a quantum harmonic oscillator, and that \psi(2 \pi) = \psi(0), how do I find an expression for the eigenstates \psi_{n} (\phi)?
\Phi = B \pi R^{2}.
Attempt at Solution
One can use
B = \nabla \times A
and
