Eigenvalues of AX - XA: Finding Eigenvectors for a Real 2x2 Symmetric Matrix
  • Context: Graduate
  • Thread starter Thread starter alchemik
    Eigenvalues
The discussion focuses on finding the eigenvalues and eigenvectors of the linear mapping L(X) = AX - XA, where A is a 2x2 symmetric matrix. The eigenvalue 0 is confirmed, with its eigenspace comprising matrices X that commute with A. The algebraic multiplicity of this eigenvalue is less than 4. The efficient method presented involves diagonalizing A using the formula A = P-1DP, leading to the eigenvalues of L being 0, 0, k1 - k2, and k2 - k1, where k1 and k2 are the eigenvalues of A.
  • Understanding of eigenvalues and eigenvectors
  • Familiarity with linear mappings and matrix operations
  • Knowledge of diagonalization of matrices
  • Experience with symmetric matrices and their properties
  • Study the process of diagonalizing matrices, specifically for symmetric matrices
  • Learn about the properties of eigenvalues in linear mappings
  • Explore the implications of commuting matrices in linear algebra
  • Investigate the application of the Jordan form for non-diagonalizable matrices
Mathematicians, students studying linear algebra, and researchers working with matrix theory and eigenvalue problems.
alchemik
Hi all,
Here is this problem that I have been at for some time now: find eigenvalues and corresponding eigenvectors of the following linear mapping on a vector space of real 2 by 2 matrices:
[tex]L(X) = AX - XA[/tex], where A is 2 by 2 symmetric matrix that is not a scalar multiple of identity.
It is clear that 0 is one eigenvalue of the above with an eigenspace consisting of all matrices X that commute with A, I do not know however what its algebraic multiplicity would be, except that it has to be less than 4. To find the other eigenvalues I looked at
[tex]AX - XA = \lambda X[/tex]
a column at a time to obtain a 4 by 4 system.
[tex]Ax_{i} - \sum^{2}_{j = 1}a_{ji}x_{i} = \lambda x_{i}[/tex]
for i = 1, 2, with j indexing the rows of A.
This approach requires me to find eigenvalues and eigenvectors of a 4 by 4 matrix, which may get messy if you have to do it by hand. Do you guys know any other, more efficient way of approaching this problem? I have attempted to use the fact that A can be orthogonally diagonalized in hopes of simplifying the above but with no success.
Thanks.
Diagonalize A: let A = P-1DP, where D = diag(k1, k2). Given any matrix X, write
[tex]X = P^{-1} \begin{pmatrix}a&b\\c&d\end{pmatrix}P.[/tex]
You can compute that
[tex]L(X) = P^{-1} \begin{pmatrix}0&(k_1-k_2)b\\(k_2-k_1)c&0\end{pmatrix}P.[/tex]
You can now directly read off the eigenvalues of L: 0, 0, k1 - k2, and k2 - k1. The eigenvectors are also obvious.
The same process applies to arbitrary diagonalizable matrices. If A is a n × n diagonalizable matrix and L(X) = AX - XA, and A has eigenvalues k1, ..., kn, then the eigenvalues of L are ki - kj, for each pair of i, j from 1, ..., n.
This is indeed a lot more tractable, thanks a lot adriank!
  • · Replies 33 ·
