Eigenvalues of Inverse Transformations
TranscendArcu
So I observed:
T(B) = λB
T-1(B) = λ'B
Also,
T-1(T(B)) = λ'λB = B
This implies,
λ'λ = 1
And so, there should be a relation
λ = \frac{1}{λ'}.
Is that right?
Looks OK to me. Note that this is quite obvious if T is diagonal, which can be achieved by a coordinate transformation such that the new coordinates are along the Eigenvectors.
So this is a similar sort of problem, so I'll ask about it here:
T(1,0,0) = (1,1,0)
T(0,1,0) = (2,2,0)
T(0,0,1) = (0,0,1)
Thus, the matrix relative to the standard basis is:
\left| \begin{array}{ccc}<br /> 1 &amp;2&amp;0 \\<br /> 1&amp;2&amp;0 \\<br /> 0&amp;0&amp;1 \end{array} \right|
Δ_T (t) = det(\left| \begin{array}{ccc}<br /> 1 &amp;2&amp;0 \\<br /> 1&amp;2&amp;0 \\<br /> 0&amp;0&amp;1 \end{array} \right| - tI)
I have this as equaling,
(1-t)[(1-t)(2-t)-2] = (1-t)(-3t+2t^2). First of all, I don't know if this is right. If it is right, I don't know how to interpret it.
Of course, I know I also have to do the other parts of the problem, but I'll get there eventually :)
You are computing the characteristic polynomial. Once you find that the roots are the eigenvalues. (1-t)[(1-t)(2-t)-2] is right, the other side isn't. You want to factor it.
TranscendArcu said:
So I observed:
T(B) = λB
T-1(B) = λ'B
Also,
This implies,
λ'λ = 1
λ = \frac{1}{λ&#039;}.
Is that right?
Your conclusion is correct but I'm not sure I agree with your proof. In particular this
T-1(B) = λ'B
is only true if B is an eigenvector of T, and that's not really clear a priori. Just say that B is an eigenvector of T so
T(B) = λB
Apply T-1 to both sides
T-1(T(B)) = T-1(λB)
T is a linear operator (I assume) ... I'll let you finish the argument. It's pretty trivial.
Also as to the diagonalization comment, while I agree that's a good way to think about it intuitively it's not a good technique for a proof. Obviously there are issues with some finite dimensional space maps being non-diagonalizible; but even more fundamentally for a Hilbert space I think you would need the operator to be compact to have any hope of such an approach working.
Dick said:
You are computing the characteristic polynomial. Once you find that the roots are the eigenvalues. (1-t)[(1-t)(2-t)-2 is right, the other side isn't. You want to factor it.
Should I write: (1-t)[(1-t)(2-t)-2 = -(t-3)(t-1)(t). This is the characteristic polynomial. Thus, the roots are 3,1,0. These are the eigenvalues. If I have equations,
(1-t)x + 2y = 0
1x + (2-t)y = 0
(1-t)z = 0,
and I plug in for t=0,1,3, I find for t=3 that eigenvectors are multiples of (1,1,0). For t=1, eigenvectors are multiples of (0,0,1). For t=0, eigenvectors are multiples of (-2,1,0). The matrix is diagonalizable because T has three linearly indep. eigenvectors.
Because these vectors are linearly independent, and because the number of vectors = dim(R3), these vectors span R3. Thus, R3 is the eigenspace of T (?)
How does that look?
T-1(B) = λ'B
T(B) = λB
T-1(T(B)) = T-1(λB)
Hmm. What's the problem with writing:
T-1(T(B)) = T-1(λB) = λ'λB = B
And then arriving at an identical conclusion?
T-1(λB) = λ'λB
This is only true if B is an eigenvector of T-1, (sorry guess I forgot the exponent in my first post) and I don't think that's clear ahead of time.
Okay. How about this:
T-1(T(B)) = T-1(λB) = B. This implies,
T-1λ = 1. And thus,
T-1 = 1/λ,
which confirms the relation,
T-1(T(B)) = (1/λ)λ B = 1B =B
It occurs to me that this isn't very good notation. But is the idea here right? Or am I still off?
TranscendArcu said:
T-1λ = 1. And thus,
:confused:
you have a matrix on one side of the equation and a scalar on the other
T-1λ(B) = 1(B). And thus,
T-1(B) = 1/λ (B),
T-1(B) = 1/λ (B),
You're done here. This line means exactly that B is in fact an eigenvector of T-1 and the eigenvalue is 1/λ.
This is self evident from the definition of the inverse, and does not need to be confirmed.
This is a problem nearly identical to the 2nd problem in this thread. Since I'm still kind of sure about the material, I'd like my work checked here as well.
T(1,0,0) = (3,-1,0)
T(0,1,0) = (0,1,0)
T(0,0,1) = (-1,2,4)
Thus, we have the matrix,
\left| \begin{array}{ccc}<br /> 3 &amp;0&amp;-1 \\<br /> -1&amp;1&amp;2 \\<br /> 0&amp;0&amp;4 \end{array} \right|
Δ_T (t) = det( \left| \begin{array}{ccc}<br /> 3 &amp;0&amp;-1 \\<br /> -1&amp;1&amp;2 \\<br /> 0&amp;0&amp;4 \end{array} \right| - tI)
I have this equaling: -(t-4)(t-3)(t-1), which is the characteristic polynomial. The roots are the eigenvalues, which are 4,3,1.
To compute the eigenvectors:
When t=4, we have,
-x-z=0
-x-3y+2z=0
0z=0
Which implies that eigenvectors are multiples of (-1,1,1).
When t=3, we have,
-z=0
-x-2y=0
z=0
Which implies that eigenvectors are multiples of (-1,2,0)
When t=1, we have,
2x-z=0
-x+2z=0
3z=0
Which implies that eigenvectors are multiples of (0,1,0).
T is diagonizable because (-1,1,1),(-1,2,0),(0,1,0) are lin. indep.
I'm still unsure if the eigenspace is the span of the eigenvectors. If so, I guess R3, otherwise, I'm not sure.
