Can an Invertible Matrix Have Zero as an Eigenvalue?
  • Thread starter Thread starter Batman2
    Eigenvalues
Batman2
Let B be an invertible matrix
a.) Verify that B cannot have zero as an eigenvalue.
b.) Verify that if \lambda is an eigenvalue of B, then \lambda^{-1}^ is an eigenvalue of B^{-1}.
Bv = \lambdav, where v\neq0
a.) I'm pretty sure that I need to manipulate the eigenvalues definition above so that I end up with v = 0, thus contradicting the definition.
What I have so far is:
Bv = \lambdav
B^{-1}Bv = B^{-1}\lambdav
Iv = B^{-1}\lambdav
v = \lambdaB^{-1}v
If \lambda = 0
v = 0, which contradicts the definition for eigenvalues where v\neq0
Therefore \lambda\neq0
I think I am missing some crucial steps and kinda jumped ahead in my working. Am I on the right track? How can I approach this problem properly?
b.) I'm thinking of a similar approach for b.), where I would need to use the above definition and multiply through by the inverse B, and then maybe take the reciprocal of lambda.
However I'm not sure given that I can't do the first part yet. Any help would be much appreciated.Daniel
Normally, I'd say that looks like it'd work, but I am not sure as I only did this topic like 3 years ago.
and for the first one, I'd just use what the product of the eigenvalues would give in relation to B and then show how it would contradict the statement of what B is given \lambda=0
I suspect that it's that eerie feeling you get when you really start to understand something, and are surprised at how straightforward it all seems!
Just to organize what you've done a little bit (and probably with too much detail), your arithmetic has shown
Given a vector v, scalar \lambda, and matrix B:
If Bv = \lambda v and B is invertible
Then v = \lambda B^{-1} v
If, in addition, \lambda = 0,
Then v = 0
And you have correctly argued
If B is invertible, \lambda is an eigenvalue, and \lambda = 0
Then we have a contradiction​
And correctly concluded
Then \lambda \neq 0​
For (b), if Bv= \lamba v then, as you have, B^{-1}Bv= B^{-1}\lambda v or v= \lambda B^{-1}v. Now divide on both sides by \lambda.
I remember doing these problems. I think this is how I did part a:
Bv=\lambdav
Bv-\lambdav=0
(B-\lambda)v=0
If \lambda=0 then Bv=0 which can only happen if B is not invertible, which is a contradiction.
As for part b: If Bv= \lambdav then B-1v=\lambda-1v
Then B-1v-\lambda-1v=0
(B-1-\lambda-1)v=0 and you now have the definition of an eigenvalue, where \lambda-1 is an eigenvalue for B-1.
You know, you guys shouldn't be doing his homework for him.
Fortunately, from the opening poster's comments, I'm sure he had worked it out already.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
