Einstein-Hilbert Action -> GR is a saddle point?
  • Thread starter Thread starter JustinLevy
    Gr Point
JustinLevy
Einstein-Hilbert Action --> GR is a saddle point?
[Clarification: I'm not claiming GR is wrong or anything. I'm asking if there are issues in interpreting GR as an action principle, and since I assume not, why not?]
We can get the equations of GR from the Einstein-Hilbert action by finding the extremal action in variations of the metric. However, the action does not appear to be bounded below as the curvature could just go arbitrarily negative for a finite period of time. Similarly it doesn't seem to be bounded from above. So are the equations we find when solving for the extremal action actually some kind of "saddle point"?
Doesn't this prevent us from considering GR in terms of a least action principle?
Is this issue of being unbounded from below in anyway related to the problems of trying to quantize gravity?
Remember that the action is a functional of the metric; both the Ricci scalar ##R## and the factor ##\sqrt{-g}## depend on the metric. Finding the extremal action means varying the action with respect to the metric, and both factors will vary. So you can't just look at the Ricci scalar; you have to look at ##\sqrt{-g}## as well, and ask how that will vary if you vary the metric to make ##R## arbitrarily negative or positive. My understanding is that when you take all that into account, the extremal metric, i.e., the one that solves the Einstein Field Equation, is in fact a minimum of the action.
Taylor & Gray's paper, "When action is not least", <<link>> might also be of interest. I'll quote from the abstract. Perhaps I'm missing something, but basically my impression is that the action being a saddle point is not at all that unusual or anything to be concerned about.
We examine the nature of the stationary character of the Hamilton action for a space-time trajectory worldline tof a single particle moving in one dimension with a general time-dependent potential energy function U(x,t). We show that the action is a local minimum for sufficiently short worldlines for all potentials and for worldlines of any length in some potentials. For long enough worldlines in most time-independent potentials U, the action is a saddle point,that is, a minimum with respect to some nearby alternative curves and a maximum with respect toothers. The action is never a true maximum, that is, it is never greater along the actual worldline thanalong every nearby alternative curve.
Likes vanhees71
Even in classical mechanics is it the ”principle of least action”, although it is a common misnomer. The correct nomenclature would be the ”principle of stationary action”.
Likes Demystifier, romsofia and dextercioby
Less technically than the paper I mentioned, but hopefully easier to communicate in an post, consider whether or not a straight line is the shortest path between two points. Specifically, would we be better off saying that a "straight line" extremizes the distance between two points.. We are basically asking, can we use the principle of minimizing distance of a path to define a straight line, or is "extremal distance" better.
On a plane the answer is that straight lines are the curves of shortest distance between two points. On a curved manifold, we will need to be a bit more precise about our terminiology. We will use the concept of "geodesic" rather than straight lines, and we will also assume that we use the Levi-civiti connection.
Then these geodesics on a curved manifold are locally the shortest curves connecting two points, but only in a sufficiently small neighborhood of the original point. The paper I cited uses great circles on a sphere to illustrate this point, but I find it more compelling to consider geodesics on an ellipsoid. Stretch a sphere in one direction, so that it becomes ellipsoids. A curve that minimizes the distance on the sphere also minimizes it on the ellipsoid, but the great circles on the sphere that minimize the distance are "stretched".
On the sphere, there are sevaral different geodesics connecting the antipodes, points on the opposite side of the sphere.
On the ellipsoid, here are now several geodesics connecting the antipodes on what used to be the sphere. But now, some of them will be longer than others,. THus we see that there is no guarantee that a particular geodesic path is the shortest one, though it's always a local minimum.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
