Einstein, Mach's Principle, and the Speed of Light Limit
In summary: GR is not Machian; you will feel inertial forces when you rotate in an empty universe, as you can check by transforming the geodesic equation in an empty universe for an inertial observer by going to rotating coordinates. So whereas Newton proposed that one rotates wrt absolute space, Einstein proposed that you will rotate wrt the metric field (which is a substructure of spacetime), which in some sense serves as an "ether" (although it is not the same concept as before!).It's not a satisfactory answer to your question, but if I find more about this in Isaacson's biography, I'll let you know.I don't know.
e2m2a
354
I am confused about Einstein's thinking. I understand when he formulated his general theory of relativity, he wanted to incorporate 3 foundations for his theory: The relativity principle, the equivalence principle, and Mach's Principle. He believed that inertia and weight were essentially the same phenomenon, that inertia was a function of the surrounding mass of the universe. Spin a rock tied to a string, he believed the centrifugal force tugging on your fingers was essentially a gravitational effect caused by the rotation of the rock relative to the cosmic mass of the univers. Here is my confusion. All of his professional life he insisted that nothing-- light, physical causality,etc. could ever exceed the speed of light. So why would he even attempt to implement Mach's principle, knowing that no effect, wave, field,etc. could travel faster than c?
I've always thought that the way the distribution of mass and energy in the universe determines the local metric in GR is consistent at least in spirit with Mach's principle. I've always been told by people that know that this view is simply incorrect. So, if one were to spin up the distant stars respecting the speed of light and all, wouldn't frame dragging eventually effect the water in a initially non-rotating Newton's pail? Whatever...
Again, I'm not sure what Einstein was thinking. If the local metric is already determined by the total cosmic mass-energy distribution of the universe, then was he thinking that acceleration with respect to the local metric pre-determined by distant mass-energy is what actually causes the inertial force, not acceleration with respect to the distant mass-energy distribution? I don't know. Can someone throw some more light on this problem, specifically, the speed of light restriction and causality due to distant mass-energy. Inertial reactions are instantaneous reactions, so something local must be causing it. Therefore, how could Einstein try to weave Mach's principle into GR without overstepping the light speed restriction? Remember, Einstein rediculed spooky-action-at-a-distance in quantum mechanics pertaining to quantum entanglement.
Excellent question!
I think a lot of people believe Einstein rejected the notion of an ether as soon as he published his special theory, but this is not the case. E.g., in 1920 he lectured in Leiden where he stated that "if inertia determines the accelerations of masses far away, this implies an action at a distance, which is unacceptable for a modern physicist". As such he proposed to reincarnate the idea of an ether. See e.g. Walter Isaacson's biography, chapter 14. As I understand it now, in that lecture he proposed to do so because his theory of GR is not Machian; you will feel inertial forces when you rotate in an empty universe, as you can check by transforming the geodesic equation in an empty universe for an inertial observer by going to rotating coordinates. So whereas Newton proposed that one rotates wrt absolute space, Einstein proposed that you will rotate wrt the metric field (which is a substructure of spacetime), which in some sense serves as an "ether" (although it is not the same concept as before!).
Likes DanielMB
I certainly can't comment on what Einstein was thinking or even grasp why one should care so much. In the limit that light might shine both ways, how is it that GR is not an answer to the above question? In EM the local fields are determined by the global sources in a causal way, why is GR different? The Wiki discussion throws up Godel's rotating universe as some grand counter example. That one can find some special solution of the GR field equations that tweak poor Mach in a way he wouldn't be able to understand doesn't surprise. Mach didn't understand either relativity theory given the time period when he was writing. People tend to speak about these things like the progenitor of a theory has some choice in how the theory turns out? The facts drive the (successful) theories not the will of researcher.
haushofer said:
Excellent question!
Thank you for the response. I will have to investigate deeper into his papers on the Einstein Paper's website on his ideas concerning an ether.
There is a simple scenario that counters Mach's idea.
Two spheres separated by space, spinning in a common plane, with opposite and equal rotations.
If the reciprocal effect was due to the remaining mass of the universe spinning with the opposite rotation, the net rotation would be zero.
The spheres would still experience centrifugal effects.
Does this assume that the two spheres are the only mass in the universe? It would seem required to counter Mach's idea.
Mach would attribute equivalent centrifugal effects of a rotating mass m
if the universal mass (M-m) rotated in the opposite direction and m had no rotation.
Two masses m1 and m2, with equal rates of rotation but opposite directions, would not work per his principle.
There is also the distinction between allowed physical behavior of matter, and perception.
The distant stars rotating at speeds >c is perception, or reality confined to the mind.
Agreed. Is this due to Mach predating the relativities? If Mach was aware and understood the relativities wouldn't GR have address Mach's philosophical stand?
According to the equations of GR, yes (with some caveats related to what "spin up the distant stars" would actually mean). I suggest checking out Cuifolini and Wheeler's book Gravitation and Inertia. It goes into this general issue in excruciating detail.
Likes Paul Colby
Ciufolini and Wheeler give an interesting analogy from electrodynamics in chapter 7 of their book. If a charged body is suddenly accelerated, its electric field lines are deformed from radial into a roughly spherical shell at large distances r = ct from the region of the charge's acceleration, where c the speed of light and t the elapsed time from the acceleration event (see Figure 7.1). The field within this shell will tend to drag oppositely charge particles in the same direction as the original body's acceleration. Importantly, since the deformed field lines form a roughly spherical shell, this effect falls off as 1/r instead of 1/r2, consistent with the known characteristics of the radiative component of an electromagnetic field. This makes it plausible that extremely distant charges have an important local influence, because if charge distribution is on a large scale uniform, the quantity of charge in a shell or radius r is proportional to r2, so the effect of distant charges can predominate.
Now look at it the other way around: the body is stationary while all other charges in the universe accelerate. The radiative component of the all those other charges drag the body along with them, similar to Mach's principle.
The problem of course is this effect is not instantaneous (if you stick with retarded potentials) while inertia is. Where I'm puzzled is, the author's do not seem to rely on this analogy to support their account of Mach's principle. They cite Ellis, Sciama, and Fermi saying the charge "does not see" those other distant charges, instead it "feels them." But here is where I get lost, because I'm not sure what it means to "feel" distant charges but not "see" them. Somehow Ciufolini and Wheeler attribute inertia to the distribution of other gravitating systems on a space-like hypersurface where there is no possibility of any radiative effect being involved, but I haven't been able to follow their reasoning.
Likes Povel
But that's because, in the analogy you described, the distant charge is accelerated, while the charge sitting right next to us, the observer, is not. So of course it's going to take time for the effects of the distant charge accelerating to propagate to us.
In the case of inertia, it's the other way around. The distant masses in the universe are just sitting there, but the mass right next to us, the observer, is accelerated, and resists the acceleration--meaning, it requires a force to accelerate it. Since the force is being applied right here, and the acceleration is right here, the resistance is also right here, so we observe it immediately. The effect of the distant masses is not their effect "right now" but their effect one light-travel time ago, but since the distant masses aren't accelerating, they're just sitting there, it looks the same to us as if it were their effect "right now", because there's no change in the distant masses that has to propagate to us.
Thanks, PeterDonis. Agree that if the distant masses didn't accelerate, then their retarded effects do the job. But then you can't reverse the situation and say (based on the analogy) that there is no difference whether the local body accelerates or the rest of the universe accelerates instead (as you could for different inertial frames in special relativity).
You're confusing coordinate acceleration and proper acceleration. In the scenario I was talking about, the distant masses have zero proper acceleration: they are in free fall. It's the local object that has nonzero proper acceleration: it feels weight. That's true regardless of whether we choose a frame in which the local object is at rest and distant masses "accelerate" (in the coordinate sense), or if we choose a frame in which the distant masses are at rest and the local object has coordinate acceleration as well as proper acceleration.
To put this another way: if some distant mass had a rocket attached to it and the rocket were turned on, we would not feel the effects of that on inertia here instantaneously. The effects would have to propagate to us. They would propagate as gravitational waves, just as the effects of accelerating a charge propagate as electromagnetic waves.
Likes Paul Colby
Isn't the point behind Mach's principle (at least some versions of it) to posit the "relativity" of acceleration (without distinguishing between proper or coordinate)?
What I mean is, one should not be able to tell whether it is the observer or the distant masses that are accelerating, because the effect of such masses on a observer "resisting" their frame-dragging effect in the latter case would generate the sort of inertial forces that are associated with proper acceleration (i.e. , the water in Newton's bucket rising).
If this is the case, I'd expect that the local observer mass would also generate a counter dragging effect on the distant masses. In the frame were distant masses are not accelerating, then, the accelerated observer would produce miniscule "inertial forces", so they would also feel "weight".
By the way, regarding Wheeler and Ciufolini's book, their quote concerning the instantaneous effect of inertia referenced by Elemental is the following:
The sign of the force therefore is such as to drag the particle in question along with all the other particles in the "universe." In other words, we ourselves have to exert "externally" a force forward if we want to hold the particle in question "stationary" against the tide of particles accelerating backward.
We can translate this result back into a statement about what happens in the frame of reference at rest with the other particles. There also, a force is required to accelerate the particle relative to all the others. But that force is not new in the world. It is the familiar force required to impart to a particle of mass m an acceleration a in the familiar frame of reference in which the faraway matter of the universe is at rest, F = ma.
However, we know that gravitation, like electromagnetism and every other primordial force, must propagate at the characteristic speed c. The elementary sum in equation (7.1.4) for the coefficient of inertia envisages a radiative interaction between particle and particle which propagates instantaneously. But how can stars at distance of 10^9 and 10^10 lt-yr respond to the acceleration of a test particle here and now in such a way as to react back upon this test particle at this very moment? This difficulty alone should be sufficient cause for dropping the elementary formulation of equation (7.1.4) and to observe that one would, at least, need to use retarded potentials.
I might be misreading this, but it seems to me they are pointing out the fact that there is indeed some problem with the istantaneous character of inertia if it is indeed a gravitational radiative interaction.
Not with the parenthetical comment you make, no. Proper acceleration is a direct, local observable; it isn't "relative". Mach's principle does not deny that at all.
The point of Mach's principle, at least as I see it (there is not general agreement among physicists on exactly what "Mach's principle" is or what it means), is to try to put together a satisfactory view of why objects feel proper acceleration in certain states of motion but not others, without hypothesizing some fixed background structure of spacetime that does not depend on the actual matter and energy content of the universe. But saying that the proper acceleration an object feels can be explained, ultimately, by the distribution of matter and energy in the universe is not at all the same as saying that proper acceleration is "relative".
Here you are talking about coordinate acceleration, which is relative in GR. But for proper acceleration, what you say here is obviously false: the observer can easily tell whether or not he has proper acceleration by using an accelerometer, or asking himself whether he feels weight.
But not the distant masses "now"--the distant masses one light travel time from now. So a local observer mass on Earth now won't generate a counter dragging effect on distant masses in the Andromeda galaxy for two million years. Any counter dragging effect of the Earth on the Andromeda galaxy now came from Earth two million years ago. We have no way of measuring any such effects directly.
But it is still possible to measure the frame dragging effect of local masses on nearby masses--that's what Gravity Probe B did. Cuifolini and Wheeler talk about that.
They are pointing out that you can't view our feeling of inertia here and now as being due to the effect of distant masses now; you have to view it as being due to the effect of distant masses one light travel time ago. That's what their reference to "retarded potentials" means.
Thanks for your quick answer PeterDonis :)
I expressed myself incorrectly. With "relative" I meant exactly the content of your last sentence, that is objects feel proper acceleration due to the effect of the distribution of mass and energy in the universe.
I agree fully, there must be a time delay between observer and distant universe and viceversa.
To me, however, this rises some question related on how the interaction travels.
Surely linearly accelerating an observer creates gravitational waves, and linearly accelerating the entire matter-energy content of the universe relative to the observer generates a (much much stronger) gravitational wave that travels toward the observer (assuming coordinate acceleration is what is needed for their appearance*), but there are situations where I don't see how any sort of wave could be generated, even though the interaction must be obviously time-delayed.
For example, consider the case of a gyroscope sitting inside a massive spherical shell with some non-negligible radius embedded in asymptotically flat spacetime (a much more simplified situation conceptually than a "rotating universe") .
The solution close to the gyroscope for a non-rotating shell is well known; the solution for a steadily rotating shell is also well known (this is the setup for Lense-Thirring effect).
I can then imagine an initially non-rotating shell undergoing a period of acceleration that ends up with a shell rotating with some constant angular velocity.
The gyroscope axis will initially be aligned with some distant star, then a ##\Delta t## after the shell starts accelerating it will start to precess more and more until the shell velocity becomes steady. At this point, after a time delay proportional to the shell radius, the gyroscope precession will also stabilize.
Is the above picture correct?
If it is so then, since the effect is time-delayed, it seems like a radiative interaction should be at play.
But if the shell is perfectly spherical it cannot generate any quadrupolar gravitational wave, so what sort of radiation is involved here?
(If all the above is considered excessively off topic, feel free to remove it, I'll open another thread)
Ok, I did notice they referenced retarded potentials, but I have some lingering doubt sabout the picture they portray.
If inertia is a gravitational radiative interaction, as Wheeler and Ciufolini conclude, it must involve real radiation, even though it is the result of coordinate acceleration*. But if so, how does the matter along the past lightcone "know" when to radiate the appropriate field to produce the right force at the right time on the locally accelerated body? *As far as I can tell, the consensus is that a charge falling in a gravitational field would be seen to radiate by an oberver on the ground, but not by an observer falling along with it. So the only thing that counts for radiation to be detected is coordinate acceleration. I suppose it should be the same with gravity.
"Travel" can mean any of a number of things. Gravitational waves is one, but it's not the only possible way of thinking of how an interaction involving the geometry of spacetime would "travel".
No, it doesn't. There is actually an exact solution known for this case, called the "Kinnersley photon rocket", which is known to have no gravitational waves anywhere.
It seems so to me, but I don't think any exact solution is known for this case.
If the shell is perfectly spherical before it starts spinning, it won't stay perfectly spherical; that's impossible. It has to deform, and the deformation, since it's due to a time-varying rate of spin, will produce (I think) a time-varying quadrupole moment and thereby cause GW emission.
Inertia is not the result of coordinate acceleration. It's the result of proper acceleration. More precisely, "inertia" in the sense of "whatever it is that makes you feel weight" is the result of proper acceleration.
First, gravity is not the same as electromagnetism, although there are similarities. Gravity obeys the equivalence principle; electromagnetism does not. And it's the equivalence principle that let's us view gravity as an effect of spacetime geometry. Gravitational waves are waves of changing spacetime geometry, so you should not expect analogies with EM like the one you are making here to hold.
Second, the EM radiation seen by the observer on the ground from a free-falling charge is due to the observer's proper acceleration, not the charge's coordinate acceleration. The observer free-falling with the charge sees no radiation because he has zero proper acceleration.
So there are ways, different from gravitational radiation, in which the influence of some distant mass can propagate to us in a causality-respecting way? For example?
Very interesting, I didn't know about this solution, thank you for mentioning it.
So, if I'm intepreting it correctly, it consist of a point particle emitting "null fluid/ photon radiation" and accelerating due to the recoil. This system does not emit gravitational waves because the contribution from the point particle mass and the photon cancel each other, at least if the anisotropy of the photon flux is purely dipolar. (https://arxiv.org/abs/gr-qc/9412063)
(EDIT: In a later paper Bonnor found out that a generalized Kinnersley photon rocket does not radiate even if the photon flux contains quadrupole terms (https://iopscience.iop.org/article/10.1088/0264-9381/13/2/015). However this has been challenged by other treatments of the problem, for example https://arxiv.org/pdf/gr-qc/9711001.pdf . This is really weird)
Does this constitute a problem for the picture that was described above of dragging and counter dragging between the local observer and the distant universe?
If the dragging and counter dragging interaction is radiative it should involve gravitational waves presumably. However this photon rocket does not emit any, even though it is properly accelerated, and thus feels inertia.
I see. It would be very interesting if such exact solution could be found. I suppose this situation might still be studied numerically, right?
Indeed, it makes sense. I didn't thought about the shell deformation.
EDIT: I thought a bit more on this, but I still see some issue.
In principle, I can make the shell of whatever material I want.
(Since Lense-Thirring scales with angular momentum, and so on the moment of inertia, for any given final angular velocity , if I make the shell out of, say, carbon nanotubes I will presumably need to make it bigger to obtain the same dragging effect I would obtain if it was made of, for example, steel.)
During the speed up phase, then, the two shells will deform into an oblate spheroid by a different amount, and consequently, it would seem like the amount of gravitational waves they produce is different, even though the final dragging effect on the gyroscope is the same by construction.
Even though I cannot make a perfectly rigid shell, it seems like I can arbitrary reduce its deformation to a tiny amount.
With "it is the result of coordinate acceleration" I was referring to "real radiation". In light of your latest post I suppose that the correct thing to say would be that radiation is the result of proper acceleration of either the oberserver mass or the distant masses or both.
But even so, I can't make sense on how does the matter along the past lightcone "know" when to radiate the appropriate field to produce the right force at the right time on the locally accelerated body. How does this work?
I didn't mean to stretch the similarity between the gravitational and electromagnetic case beyond their limit. I was thinking more about a linearized gravity - EM comparison.
In this limit, it should be possible to make at least certain comparisons regarding radiation emission, right?
Information. The light from distant stars and special events certainly cause astronomers to stay up at night.
Of course, but what I meant was specifically how an interaction involving the geometry of spacetime could "travel" to us aside from propagating through gravitational waves.
I know Wheeler and Ciufolini talk about "instantaneous" elliptical constraints equation applied on a space-like hypersurface, but this looks to me more like a convenient way to sidestep a complicated retarded integration along the past lightcone which is nonetheless physically analogous to it (because what's physically happening involves a time-delayed interaction).
Consider the static field of a planet like the Earth. The influence of the Earth at some point distant from it is not due to the Earth "now"--it's due to the Earth in the past light cone of that point. But because the field is static, there are no gravitational waves. So if you think of the influence of the Earth at a given point as being due to the Earth in the past light cone of that point, you have to think of that influence "propagating" somehow from the Earth in the past light cone to the point, without there being any gravitational waves.
Note that the same issue arises in EM: the Coulomb field of a point charge does not instantaneously affect another charge at a distance; the influence of one charge on another is due to the first charge in the past light cone of the second. But there are no EM waves present if the EM field is just the static Coulomb field.
But it might not be. You can have distant masses affecting the spacetime geometry here and now without gravitational waves propagating. I gave an example in post #24.
Yes.
No, because the gravitational wave emission also varies with things like the density and moment of inertia of the shell. If the GWs are what is propagating the change in precession rate (from zero to some nonzero value) to the gyroscope, then if the change in precession is the same, the GWs must be the same.
No, you can't, because the final deformation is due to a change in spacetime geometry that is necessarily finite if the final angular velocity is finite. The only way to make the deformation arbitrarily small would be to make the angular velocity arbitrarily small.
It doesn't have to "know" anything. The causality is forward, not backward. The locally accelerated body "knows" how much proper acceleration to feel based on the local spacetime geometry. In other words, the local spacetime geometry contains all of the information about the path curvature of every possible local worldline, and "path curvature" is the same as "proper acceleration".
Likes FactChecker
Not the ones you're trying to make. Linearized gravity is still not the same as EM, because, as I said, gravity obeys the equivalence principle and EM does not. Also, the lowest order EM radiation is dipole while the lowest order gravitational radiation is quadrupole (because gravity is spin-2 while EM is spin-1).
Ok, I see how this works for static situations, but the discussions over Mach's principle usually deal also with acceleration, both proper and coordinate, of either the local observer mass or the distant universe/"cosmic shell".
I don't see how it is possible to evade the need of employing some sort of radiative interaction in such circumstances.
I guess one would truly need an exact/numerical solution to properly discuss this, but if the shell is being accelerated by some external mean and the local observer is resisting it, and this situation is postulated to be both kinematically and dynamically analogous to simply have the local observer accelerate with respect to the rest frame of the shell, as Wheeler and Ciufolini seem to suggest, wouldn't this mean that the interaction must be radiative, since the local observer has the freedom to undergo all sort of arbitrary cycles of acceleration?
I agree with the the second sentence of course.
Regarding the first, however, I did consider those parameters in my example. Maybe I can refine it a bit:
Consider two nearly spherical shells, made of different materials, one more dense than the other but not necessarily with an higher tensile strength (i.e, steel and carbon nanotubes).
The shell made of the stronger material is built to have an oblatness greater than the other shell, so that when the two shell are spun to the same final angular velocity ##\omega## their deformation will make their moment of inertia the same. The density along their surface will also change due to stress, but by a different amount.
According to Lense-Thirring formula, then, their dragging effect on a gyroscope in their center will be the same once they reach and keep their final angular velocity.
(Of course this formula is a weak-field approximation for a spherical spinning body, but I suppose it should keep being valid if the oblatness is kept small)
The gravitational wave emission of the shells depends on the time variation of their quadrupole moment (actually on the second time derivative of the quadrupole moment).
During the spin-up phase the shells density and moments of inertia change, but not by the same amount in general. This would seem to indicate that the time-rate of change of their quadrupole moment is not equal.
Is there something incorrect in this picture?
Ok, rigorously I cannot do that "arbitrary", but by simply changing the material I can surely reduce the deformation by orders of magnitude for any final ##\omega## by relying on the tensile strength of the material.
Sure, I agree with all of this, but if Mach's principle is about why certain states of motions are associated to proper acceleration and not others I don't think it is enough to stipulate that such information is contained in local space-time geometry/gravitational field without also providing a mechanism by which the local spacetime/gravitational field enforces such distinction.
At the end of the section of Gravitation and Inertia I quoted, Wheeler and Ciufolini wrote the following:
"Therefore, what can we conclude from this analysis? First, nothing provable. Without using a sound theory of gravitation, we cannot expect a soundly founded theory of gravitational radiative reaction. Second, we have translated the Machian idea that "inertia here arises from mass-energy there" from a vague idea to a concrete suggestion with two components: first, the mechanism of coupling is not some new feature of nature but long-known gravitation and, second, it is the radiative or acceleration-proportional component of this interaction that counts. Finally, we recognize that we cannot go further in translating these intimations and suspicions into mathematically sound conclusions until we make use of a properly relativistic theory of gravitation at our disposition for the doing of it. "
Even though they are very cautious with the EM-GR analogy, they seem to accept the suggestion that the above mentioned enforcing is obtained through a radiative interaction, and that inertia is in fact a sort of "radiative reaction". (I'd also like to mention the fact that Sciama, their target in this section for his use of the EM-GR analogy, had already put his ideas in a properly general relativistic form in 1964, in a little known paper. The radiativeness is still there, see here).
To return to my question, then, if inertia is enforced by such radiative interaction with local space-time, it would seem like, in the rest frame of the locally accelerated observer, such radiation must have departed from the distant masses billions of years before the observer started accelerating. (In the meanwhile, I found a peer-reviewed paper by Grøn that claim this, see here , page 1726). This looks weird.
I guess it would be possible to claim that this is just an artifact of the chosen frame of reference and that the observer is really just somehow interacting non-radiatively with local-spacetime, but if so the nature of such interaction is left obscure (everyone who studied this seems to talk about a radiative interaction of some sort) and one cannot claim that all frames of reference give a coherent dynamical description of reality, because in this case there would be no artifacts, only equally real physical descriptions.
I know about these differences, but do they imply that the situation for a falling mass as seen from an observer on Earth is different than the case of a falling EM charge? Doesn't the observer standing on Earth see the mass emitting GW, while an observer falling along sees none?
I've read that one way to calculate the energy carried by GWs is to use pseudo-tensors, and these have the characteristic of being local but frame dependent, so that they vanish in free-falling frames. To me, this sounds very similar to the result in EM case.
The discussions almost always deal with one of two cases:
(1) Linear proper acceleration of a test object. This doesn't require radiative interaction because the spacetime geometry itself can be static; only the motion of the test object is not. So the proper acceleration felt by the test object can simply be attributed to the local spacetime geometry.
(2) Proper acceleration due to rotation. This is the most commonly discussed case because of the seemingly "absolute" nature of the rotation: the rotating object (considered as a test object) feels proper acceleration, but it seems like if we adopt a frame where it's the distant universe that's rotating, not the object, then the distant universe should be feeling the acceleration, not the object--which is contrary to observation. However, this case can still be modeled as stationary (i.e., rotation rate not changing with time), which again means no radiative interaction is required: again, the spacetime geometry does not have to change, so the proper acceleration of the rotating object can again simply be attributed to the local spacetime geometry.
More general non-stationary cases still follow the principle that proper acceleration is due to the local spacetime geometry, but now accounting for the local spacetime geometry might indeed require some kind of gravitational radiation to be propagating from a source in the past light cone.
I don't think that's what Cuifolini and Wheeler are suggesting. If there is some external source of energy acting on the shell, it's acting on the shell, not the local observer: that's an invariant and doesn't change if you change frames. More generally, if the local observer is in free fall, with zero proper acceleration, while the shell has nonzero proper acceleration, that's an invariant and doesn't change if you change frames.
Much of the discussion around Mach's principle fails to recognize that invariants like these are ways in which the situations are not "kinematically and dynamically analogous" if you change frames.
Then the shells aren't identical before they are spun up. You've basically adjusted the original (before spin-up) composition of each shell to ensure that they have the same frame dragging effect after spin-up.
Actually on the third time derivative of the quadrupole moment.
Sure, because the shells start out in different states but they have to end up in the same state, at least as far as frame dragging is concerned. Note that the time it takes to spin up the shells to the same final state will, in general, be different, because the shells' initial states are different. And for the final frame dragging effect to be the same, all that has to be true is that the total integrated change in the shells is the same; it doesn't have to be true that they change in exactly the same way at every instant, which is what would be necessary for their GW emissions to be identical.
The local spacetime geometry is the mechanism. Specifying the local spacetime geometry is equivalent to specifying the proper acceleration for every possible state of motion in the local spacetime. They are the same thing.
The discussions over Mach's principle have centered on how the local spacetime geometry gets determined by the matter/energy content of the rest of the universe. General Relativity gives a solution to that: the Einstein Field Equation.
I don't have my copy of the book handy to look at the context, so I'll have to defer comment on this until I can dig it up. (Similarly, I haven't read that Sciama paper before, only his earlier one from the 1950s where he uses a theory of gravity that is admittedly not GR, and is only supposed to be an initial investigation. So I'll have to defer comment on that until I can read the paper.)
Yes, this is just another way of saying that the local spacetime geometry is determined by the matter/energy present in the past light cone, and that propagating gravitational waves are what carry information about changes in the matter/energy distribution in the past light cone to here and now.
Yes; I don't think classical GR itself can be interpreted as having a "radiative interaction" for all inertia. Most of the commonly used spacetimes in GR (Schwarzschild, Kerr, FRW) have no gravitational waves present, but objects still have inertia. I personally have no problem with this, but some people do.
If the object is free-falling radially, I think neither observer will see GWs being emitted. For cases with angular motion involved, I'm not sure; I would have to look at the detailed math (and I don't know if there is any analysis of this case in the literature).
1. What is Mach's Principle and how does it relate to Einstein's theory of relativity?
Mach's Principle is the idea that the inertial forces of an object are determined by the distribution of matter in the universe. Einstein's theory of relativity incorporates this principle by stating that the presence of matter and energy in the universe affects the geometry of space and time, which in turn affects the motion of objects.
2. How does Einstein's theory of relativity explain the speed of light limit?
Einstein's theory of relativity states that the speed of light in a vacuum is the maximum speed at which all forms of matter and energy can travel. This is because the speed of light is a fundamental constant in the universe and cannot be exceeded by any object or force.
3. Can the speed of light limit be broken?
No, according to Einstein's theory of relativity, the speed of light limit cannot be broken. This has been confirmed by numerous experiments and is a fundamental principle of our understanding of the universe.
4. How does the speed of light limit affect our perception of time and space?
The speed of light limit plays a crucial role in Einstein's theory of relativity, which states that the passage of time and the distance between objects are relative to the observer's frame of reference. This means that time and space can appear to be distorted depending on the relative speeds and positions of the observer and the objects they are observing.
5. Why is Einstein's theory of relativity important for understanding the universe?
Einstein's theory of relativity revolutionized our understanding of space, time, and gravity. It has been confirmed by numerous experiments and has been used to make accurate predictions about the behavior of objects in the universe. It also paved the way for the development of technologies such as GPS and has greatly influenced modern physics and cosmology.
