Elastic Problem. Aluminum Wire in Horizontal Circle
The discussion focuses on calculating the angular velocity required for an aluminum wire to produce a specific strain while supporting a 1.20-kg object swinging in a horizontal circle. The wire, measuring 0.850 m in length with a diameter of 0.780 mm, utilizes Young's Modulus (Y) of aluminum, valued at 7.0 x 1010 Pa. The correct angular velocity is determined to be 4.86 rad/s after correcting an initial miscalculation involving centripetal force and the geometry of the system.
  • Understanding of Young's Modulus and its application in material stress analysis
  • Knowledge of centripetal force and angular velocity equations
  • Familiarity with basic geometry for calculating areas of circular cross-sections
  • Ability to manipulate algebraic equations to solve for unknowns in physics problems
  • Study the derivation and application of Young's Modulus in various materials
  • Learn about centripetal acceleration and its relationship with angular velocity
  • Explore the concept of strain and stress in materials under load
  • Investigate the effects of different materials on mechanical properties in engineering applications
Students in physics or engineering disciplines, particularly those focusing on mechanics and material science, will benefit from this discussion. It is also useful for anyone involved in practical applications of material stress and strain analysis.
XwyhyX
An aluminum wire is 0.850 m long and has a circular cross section of diameter 0.780 mm. Fixed at the top end, the wire supports a 1.20-kg object that swings in a horizontal circle. Determine the angular velocity required to produce a strain of 1.00  10–3.
Y of Aluminum = 7.0x1010
Y = \frac{Stress}{strain}
Stress = \frac{F}{A}
Fc = ω2R
I use Young's Modulus with the definition of stress and I get the equation
Y = \frac{F/A}{Strain}
Then I can solve for F
A = \frac{∏(0.780)<sup>2</sup>}{4} = 4.77x10-7
F = Y x Strain x Area
Okay, now I have the force which will give me the strain that is needed. I'll apply it in an object rotating in a horizontal circle, The force that I used will be the one on the X axis. So
Fc = Fsinθ
and also
R = Lsinθ
Using the equation of Centripetal Force I get the equation for angular Velocity
ω = \sqrt{\frac{Tsinθ}{Lsinθ}}
Finally I get the value of 6.27 rad/s
I just want to know if I did it right. Because I don't have the correct answer for this. Thanks :D
Oops. What a simple mistake :|
So
ω = sqrt(Fsinθ/mLsinθ)
giving an answer of 4.86 rad/s?
  • · Replies 19 ·
