DefaultName
- 179
Determine if the CT systems are 1) casual or uncasual 2) memory or memoryless.
Definitions:
Casual: If for any time t1, the output response y(t1) at time t1 resulting from input x(t) does not depend on the values of the input x(t) for t > t1.
Memory: If the output at time t1 depends in general on the past values of the input x(t) for some range of values of t up to t=t1.
x(t) is random input and y(t) is the output of x(t)
For Eq1:
y(t) = |x(t)| = \left\{ \begin{array}{l}<br /> x(t)\; \mathrm{if}\, x(t) \geq 0 \\<br /> -x(t)\; \mathrm{if}\, x(t) < 0<br /> \end{array}\right.<br />
I said this system is CASUAL and MEMORYLESS.
For Eq 2:
y(t) = \int_0^t\lambda x(\lambda)d\lambda
I said this system is CASUAL and has MEMORY.
Definitions:
For Eq1:
- Casual - because at time t, y(t) will depend only t from the input function x(t), not some other arbitrary t value.
- Memoryless - because the outputs at time t do not depend on previous inputs.
For Eq 2:
- Casual - because at time t, it doesn't really depend on the future. It only depends on the past, so I'm guessing casual. *This I'm not too sure about*
- Memory - because the outputs at time t do depend on previous inputs since youre taking the integral from 0 to time t. *I'm almost sure about this one*
