Electric Dipole - Oppositely charged hemispheres
ModusPwnd
A sphere of radius a carries a uniform charge density \rho_0 in one hemisphere and the opposite charge density -\rho_0 in the other hemisphere. The charged sphere produces an electric potential \Phi (r,\theta,\phi). For r>>a, the potential to leading order is of the form,
<br /> \Phi(r,\theta,\phi) \approx \frac{g_n(\theta,\phi)}{r^n}<br />
Find g_n(\theta,\phi) and the numerical value for n.
I presume the multiple expansion could be used, but this was a test question so I think I could do it without having the expansion memorized.
Any ideas?
Thanks!
If you had to get an expression for gravitational force exerted by this body at large distances, except that one-half would consist of "negative" matter, what would you do?
If I wanted the gravitational force, I would set up the integral over the region, taylor expand it and then integrate the leading term. Does that sound right?
Plus, since I need potential and not force, it will be easier since its a scalar.
That sounds good overall. You want to find the c.m., pretend all the charge is there, now you have a standard dipole. Potentials may be the way to go, but I'm not sure. There are probably formulas floating around out there in cyberspace giving the c.m. of a hemisphere ... I would forget about Taylor series expansions. The formula for the field at large distances from a dipole is very standard textbook stuff.
The question clearly asks for the leading order term of the potential though.
I interpreted that to mean the far-field formula. The far-field formula IS a first-order ("leading") approximation. That's why it's called far-field. Does not apply when near the dipole, gets too inaccurate. It's 100% accurate only at infinity.
See http://hyperphysics.phy-astr.gsu.edu/hbase/electric/dipole.html
Look at "dipole moment" part. Not that z has to be >> r, the distance between the spehers' c.m. in your case.
However, I just noticed they want an expression for everywhere around the dipole (albeit at far distances). The formula in the link only givs the field along the line z, perpendicular to r.
This is a bigger deal than I thought. May come back to it, might not be too bad.
Here's the best I've found on your problem:
http://phys.columbia.edu/~nicolis/Dipole_electric_field.pdf
If the last equation is expanded in spherical coordinates, that should be the answer. I would set up the dipole along the z axis, with the origin half-way between the two effective point charges.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
