Electric Field between two Charges
In summary, at 2, 3 and 6 m from the positive charge, the electric field is negative, with a magnitude of 750, 3375 and 18000 amperes, respectively.
Dillion
39
A positive charge of 3 microCouloumbs is at the origin. A negative charge with the same magnitude is 8 m away along the x direction.
a) What are the magnitude and direction of the electric field at the points between the two charges, 2, and 4, and 6m from the positive charge?
b) What is the electric potential at each of these three points? (The reference point, where V=0 is infinitely far away).
V=Ed
Electric Field = Qk/r^2
a) (3*10^-6)(9*10^9)/2^2 = 6750
(3*10^-6)(9*10^9)/6^2 = 750
7500 to the right
(3*10^-6)(9*10^9)/4^2 = 3375 to the right(3*10^-6)(9*10^9)/6^2 = 750
7500 to the right
b) V=Ed
Electric field at 2m
7500 * 2 = 15000
Electric field at 4 m
3375 * 4 = 13500
Electric field at 6 m
7500 * 6 = 45000I'm confident in A but not in b. Please help
For part b, you can see from part a that the electric field is not uniform (same magnitude and direction) as you move from the origin towards the second charge. So your equation V = E*d doesn't hold because E is not a constant value. You would have to integrate: ∫E(x)⋅dx.
Instead, use the formula for the electric potential vs distance for a point charge.
What is that formula?
It should be in your text or course notes. It's a very common formula based on Coulomb's Law. You could also do a web search on "Electric potential due to a point charge".
Electric Potential = qsk/r ?
Hmm. Maybe... Can you explain what "qsk" represents?
point source charge
Dillion said:
point source charge
I'd have to say almost but not quite. Is "qsk" one variable? Or is Coulomb's constant "k" a separate value?
oh yeah sorry qs times k which is 9*10^9 all divided by r
Okay, presumably qs is meant to be qs. (Note that you can use the x2 and x2 buttons in the edit panel header to create sub- and superscripts).
So, using that formula in much the same way as you used the one for the electric field, find the electric potential at the given locations. Note that electric potential is a scalar quantity, so you don't have to worry about vector addition this time.
b) V = qsk/r
(9*10^9)(3*10^-6)/2 = 13500
(9*10^9)(3*10^-6)/6 = 4500
= 18000
is this how I would do find the electric potential at point 2?
Very close. You need to take into account the signs of the charges. Isn't point two equidistant from both charges? Point one was at 2 m from the positive charge, point two was at 4 m, and point three at 6 m?
Wouldn't the signs all be positive because a positive particle would move to the right away from the origin and towards the negative particle at 8 m
Nope. As I said before, electric potential is a scalar property, not a vector. All that matters is the sign of the charge and the distance.
I'm not sure how to continue. Having a positive charge near the origin would increase electric potential and if it was closer to the negative charge electric potential would decrease
Yes. That's not a problem.
Edit: If you were to plot the electric potential vs position between the two charges you'd get a curve that looks something like this:
Need more help please
Apply the potential formula at each point using the signed charges and distances from each charge. Sum the contributions from each.
b) V = qsk/r
= 18000
I still don't understand why this is incorrect. Everything is in the positive direction
You aren't paying attention. You must incorporate the signs of the charges. Direction does not matter: voltage is a scalar quantity and has no direction associated with it. All that matters is the signed charge and the distance from it.
b) V = qsk/r
(9*10^9)(3*10^-6)/6 = -4500 (electric potential decreases)
-4500+13500 = 9000
Yup. But you should incorporate the sign of the charge into the equation so it's obvious where the sign of the result comes from. Thus:
(9*10^9)(-3*10^-6)/6 = -4500 (electric potential decreases)
1. What is an electric field?
An electric field is a physical quantity that describes the influence of an electric charge on other charges in its vicinity. It is a vector field, meaning it has both magnitude and direction.
2. How is the electric field between two charges calculated?
The electric field between two charges can be calculated using Coulomb's Law, which states that the magnitude of the electric force between two point charges is directly proportional to the product of the charges and inversely proportional to the square of the distance between them.
3. What is the unit of electric field?
The unit of electric field is newtons per coulomb (N/C) in the SI system of units. In other systems, it can also be expressed in volts per meter (V/m) or dynes per statcoulomb (dyn/statC).
4. How does the distance between two charges affect the electric field between them?
The strength of the electric field between two charges is inversely proportional to the square of the distance between them. This means that as the distance increases, the electric field decreases. This relationship is known as the inverse square law.
5. What is the direction of the electric field between two charges?
The direction of the electric field is always in the direction that a positive test charge would experience a force. This means that the field lines point away from positive charges and towards negative charges.
